Procedure/techiques for adjusting Spohn torque arm?
Old Mar 6, 2003 | 07:04 PM
kcsoz20's Avatar
Question Procedure/techiques for adjusting Spohn torque arm?
I just put in a Spohn adjustable torque arm along with my FLP stage 4 4L60E.
Does anyone have a write up or can you give me the details on making the right adjustments to get the pinion angle correct with the adjustments on the torque arm?
Do I need a magnetic degree dial instrument or are there other tools or tricks?
I do know the standard pinion angle numbers run -2* for basic street use bolt on performance all the way to -4* for higher performance and dragstrip purposes.
TIA
Ken
Old Mar 6, 2003 | 07:12 PM
Grease's Avatar
Heres somebody's write up:
http://www.go-fast.org/z28/pinionangle.html
Its what I used to adjust mine because I accidentally threw away the instuctions that came with it.
Old Mar 6, 2003 | 08:15 PM
kcsoz20's Avatar
Talking Thank you!!!
That is about exactly what I needed! Now I just have to locate and angle/degree tool!
Ken
94Form
Jul 17, 2015 10:56 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
