My oil pressuser seems to low need help?
Old Mar 6, 2003 | 09:23 AM
Bad T.A.R.A's Avatar
My car at idle has oil pressure of about 8psi is this low what should I do? I am using 10x30 mobile one
Old Mar 6, 2003 | 09:39 AM
atlasengr's Avatar
Arrow
That seems about right----according to the Chilton manaul. Mine is that way too and I only have 39K mi. on the clock. Some have more than that though----nothing to get worried about.
Old Mar 6, 2003 | 09:40 AM
Gripenfelter's Avatar
Does it surge at all or always stay low?
If it always stays low try swapping in a new sending unit first or check the pressure with a mechanical guage.
Old Mar 6, 2003 | 09:43 AM
Smokn '94 Z's Avatar
Lightbulb
That seems very low to me. Mine sits between 20 & 25 PSI at Idle. Goes up to about 55 PSI under revs. I'd double check that.
Last summer my Oil pressure read about 10 & then I noticed my stock sending unit was bad. I replaced with an aftermarket gauge & all is good now.
Old Mar 6, 2003 | 09:50 AM
Well I is always low however it does go up as the revs go up. How much is a new sending unit and how much work is it to install.
Old Mar 6, 2003 | 09:57 AM
Its not hard to install.
I've never done it on a 94+ car but I think its at the back of the intake manifold on the driver's side?
Mine was way low on the driver's side above the oil pan because I have a 93.
It just screws in. Be careful of the plastic connector on the end. Easy to break in the cold.
Old Mar 6, 2003 | 10:03 AM
It is on the back of the intake manifold like stated by Gripenfelter. You will need an special socket though. I didn't need to use the socket cause I went aftermarket which is a much different sending unit then the stock one. My plastic was broke on my stock sending unit which is what caused my low readings....... Thankfully...
Do a search about the OP sending unit & you should be able to find out about the socket that I mentioned. I am sure you can do it without the socket but it is tight back there & may just benefit you.
Good Luck.
HectorM52
Jul 30, 2017 11:46 AM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
carl.froehlich
Mar 13, 2015 12:38 AM
siguy
Nov 27, 2014 10:07 AM
