CleaNing Engine Bay?
Old Mar 6, 2003 | 01:04 AM
blkn'silver94's Avatar
What do you use and how do you use it...anything goes....chemicals, water, plastic bags to keep opti dry?...how'd you do it..thanks Tony
Old Mar 6, 2003 | 01:57 AM
HungryT/A's Avatar
I clean my engine bay very often. First, I'd remove all the dirt/junk with a wet rag. Let it dry, then wipe everything down with Armor All. This gives your engine bay a very nice showcar finish
Old Mar 6, 2003 | 02:28 AM
GeneralZ's Avatar
I use tire foam...works great
Old Mar 6, 2003 | 06:50 AM
Birdie2000's Avatar
Get a wet rag and go to town on it.
Old Mar 6, 2003 | 07:12 AM
Bryan Smith's Avatar
I use the wetrag method then use Goop Engine Bright, and rinse with a garden hose, of course keeping away from the usual electrical components.
Old Mar 6, 2003 | 08:43 AM
magius231's Avatar
do yourself a favor and do not run a pressure wash over your engine bay...if your opti is even slightly leaking you will get water in it, and if you happen to hit the opti directly, you may put enough pressure on a seal to start it leaking.
Considering there are people that drive over semi-deep puddles and fry their opti, I would be extremely wary of getting running water near my engine. I like the wet rag/armor all method personally
Old Mar 6, 2003 | 02:51 PM
chesee48's Avatar
Originally posted by ACA Performance
*shrug* i pressure wash my motor all the time
No problems with doin it so far?
Old Mar 6, 2003 | 03:27 PM
94T56T-TOPDREAM's Avatar
opti
I used to wash my engine with a garden hose and heavy cleaners. They spray it with WD-40 for the show look.. looks great...but after I messed my opti up using the water on it....I will no longer be doing that. Good luck with the power washer!!!!
Old Mar 6, 2003 | 03:28 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
same here before i learned to be wary of my opti i wouls pressure wash my engine and hit deep puddles at high speed to send flooms of water 20 feet into the air all the time... needless to say i stopped when i learned about my opti but never had any problems... stock opti 54k miles, 95 formula
Old Mar 6, 2003 | 09:41 PM
I had already tried the pressure washer, ruined the OPTI..looking for a little safer method...the tire foam sounds great....that stuff cleans and shines at the same time right?...thanks for the info. Tony
Jazsun
Dec 29, 2014 12:14 PM
formula218
Dec 2, 2014 04:27 PM
kandied91z
Aug 4, 2002 02:53 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
