new clutch
Old Mar 5, 2003 | 09:49 PM
cndctrdj's Avatar
new clutch
i got my car back with my new clutch in it
ooooo it feels good to drive her again.
i got the borg werner brute force clutch. it is so light compared to the stock clutch it doesn't take any force to press it down. and it bights better than the old one. i can feel it pull past 3grand on the tach. (my old clutch was wasted)
o well just thought i would tell everyone
see ya
Old Mar 5, 2003 | 09:54 PM
jonaddis84's Avatar
What do you mean you can feel it pull past 3grand? Ive never heard of that clutch either, where do you get one, and whats the capacity?
Old Mar 6, 2003 | 06:44 AM
IDOXLR8's Avatar
I guess he was referring to the old clutch slipping past 3K.
Old Mar 6, 2003 | 09:09 PM
cndctrdj's Avatar
ya thats what i meant the old clutch slipped past 3k rpm's
borg warner the company that makes the transmission.
i don't know what the holding capacity is but my car is p*ssy so i didn't care as long as it held more than stock. and it definatly does.
check out www.borg-warner.com they have all the info
its the brute power clutch kit
Old Mar 6, 2003 | 09:51 PM
Dave88LX's Avatar
How much did it cost you to get the clutch replaced?
I've got a t-56, I'm sitting here fighting with the god damn thing Wrastling trying to separate the trans from the bell.
Shiiiiiiiiiiiiiiiiiiiiiiiit!
Old Mar 6, 2003 | 10:04 PM
jonaddis84's Avatar
Did you jack the front of the motor up?
Id disconnect the motor mounts then jack it up, its still tight with them connected, it is a bitch though, good luck.
Old Mar 6, 2003 | 10:18 PM
stik6shift93's Avatar
Whats this brute force clutch, I've never heard of it?
Old Mar 6, 2003 | 10:29 PM
cndctrdj's Avatar
i had never heard of the clutch either but its made by a good company who knows thier transmissions so i figured id try it out. the whole clutch package cost me 340, it fit my price range perfectly. i got it installed plus a new rear main seal and new fluid and reserfaced flywheel for 380. so all together it cost about as much as a cf dual friction. i normally do my own work but didn't even want to try and mess with the transmission if i can't pick it up i usually send it away to get worked on. this spring i willbe running the car so we can see if it holds down the track. for now i am very very pleased with it
Old Mar 6, 2003 | 10:33 PM
Wow I got my stage 3 ceramic, with install with new pilot bushing and rear main seal for $705.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
