opinion on monsoon please
Old Mar 5, 2003 | 07:39 PM
tubby's Avatar
i guess my mid base speakers are gone. audio shop tells me they can't replace them cause of the 2ohm 4ohm thing. so my problem is wether to find some or redo the whole system. opinion needed is on which way to go. i'm not a sound maniac but i do want decent quality. if you recommend replacing the whole system can it be done right for under 1,000? if so what brands on speakers amps that sort of thing?
thanks for the help
Old Mar 5, 2003 | 10:43 PM
CODY BEHNKE's Avatar
If you go to the right place you can get new GM / Monsoon replacements for around $38 each.
Old Mar 6, 2003 | 12:24 AM
DrMilhouse's Avatar
You've got 1000 to spend, I would say don't replace the factory crap with just more crap. As when anything breaks, this is a good time to upgrade. They're right that you can't really replace those speakers with normal speakers because of the ohm differences.
The 6" speakers that are in the rear are actually "subs" for the Monsoon system. I'd say simply don't worry about them. If you replace them, you can replace them with some after market speakers and you can power them off the deck directly (I'll keep going because you won't be using the monsoon amp any more.
Go for a decent sub ~ $150
Get an amp to power it ~$200
Put it in a Milhouse box ~$210
A decent aftermarket deck ~$250
A wiring harness and a mounting kit ~$20
Cabling and other stuff, ~$50
That brings you up to about $880
The front speakers will continue to work with the aftermarket deck. If you want to replace the back speakers you can do so with the remaining money.
I think that should give you some pretty good sound. It should be pretty easy for you to add on another amp for the front speakers when the time comes. If you plan to do that, run bigger wires than what you "need" to run the sub amp. Run 4 guage power.
HTH
Old Mar 6, 2003 | 07:16 AM
tubby's Avatar
thanks,
anyone have a part # for the factory replacements? or local source? for that kinda money i think thats the way i'll go for now.
Old Mar 6, 2003 | 02:34 PM
Monsoon Speaker Part # 16235651
Old Mar 6, 2003 | 02:45 PM
tubby's Avatar
Thanks cody,
gm parts direct actually had them for 22.00
Old Mar 12, 2003 | 12:55 PM
tubby's Avatar
part#
cody,
are you sure about that part#? i used it through gm parts direct and for some reason i got p/n 10447249 which is a 2 prong connector instead of 4.
thanks
Old Mar 12, 2003 | 01:07 PM
Damn, Im sorry I got the Part number off of the back of my SVC Camaro woofer (two wire).
The Firebirds use the DVC woofer (four wire), You will need this one.
Old Mar 12, 2003 | 02:39 PM
tubby's Avatar
no problem i'll just send them back. you wouldn't happened to know that part #?
Old Mar 12, 2003 | 06:16 PM
I have one at my buddies house I will call him and get it asap.
Old Mar 13, 2003 | 07:40 AM
tubby's Avatar
thanks again cody
Old Mar 15, 2003 | 09:20 AM
Here is the part number for the Pontiac Monsoon DVC for wire subwoofers
Part # 16217721
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
