Engine damage if you run out of n20 while spaying?
Old Mar 5, 2003 | 01:15 PM
stik6shift00's Avatar
Say you run out of nitrous while your spraying....will that mess your engine up?
Old Mar 5, 2003 | 01:56 PM
Geoff Chadwick's Avatar
You'd run really rich, but if you kept it up you might hydrolock if there's a LOT in there and the spark cant burn it all... but wouldnt you notice the nitrous pressure dropping first?
Old Mar 5, 2003 | 02:36 PM
COMNBYU's Avatar
no. if you ran out of n2o while spraying you would feel the car nose over or studder in which case you would let off. it wont hurt the motor, but if you keep in it, the motor will simply cut off. all you're doing if you keep adding fuel w/o n2o is flooding the motor. not too big of a deal.
now, if you add n2o w/o fuel, then you have a problem
its called detonation (A.K.A.- BOOM, POP, PING, BAANNNG!!)
jon
Old Mar 5, 2003 | 05:19 PM
stik6shift98's Avatar
dont spray when u have no pressure........
Old Mar 5, 2003 | 07:19 PM
lmao stik00 i see u sid spating...i think u meant spraying...
i ran my nitrous with low pressure about 600 and i was running really rich...
Old Mar 6, 2003 | 12:07 PM
stik6shift93's Avatar
It'll foul your plugs up, and it isn't great for the cats either.
Old Mar 6, 2003 | 12:16 PM
chesee48's Avatar
What happens if your using no cats?
Old Mar 6, 2003 | 12:41 PM
No cats=no worries. Cats like to be run around 14.7 af, not like 6 to 1 or something similar that would be seen spraying without the nitrous. The fat of an af mixture will ruin your cats if it happens enough.
Old Mar 6, 2003 | 06:21 PM
nothing...because your not hurting the cats since their not there
Old Mar 6, 2003 | 06:52 PM
thanks alot..ill just cheak the presure before
Old Mar 7, 2003 | 02:02 AM
Twice The Fun's Avatar
this is just my thought, but if u feel it run out of juice, couldnt u just disarm it (aka flip the switch off), and finish the run all motor....with no damage done?
Old Mar 7, 2003 | 09:43 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
my friend and i wondered the same thing
flipped the switch with the bottle closed-
car just stuttered
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
