timing?????????
Old Mar 5, 2003 | 11:29 AM
qwick_trip's Avatar
timing?????????
ok i am installing my nos dry kit, and i need to know am i going to need to change my timing or not?? i have no idea what to do so full me in please?
Old Mar 6, 2003 | 01:31 AM
texlurch's Avatar
What size shot? Do you have a power programmer or other (they advance the timing)?
Need just a little more info..
normally a 100 shot is fine with a stock timing curve
150 shot needs 2-4 degrees pulled out, depending on the kit
My experience is NOS needs more timing pulled out then the NX kits do.
Old Mar 6, 2003 | 09:08 AM
qwick_trip's Avatar
thinking anywhere from 100-150 dos dry kit. i don't have a power programmer or power chip. i have nothing that advances timing. so if i need to pull timing what to i have to buy to do that ?
Old Mar 6, 2003 | 12:12 PM
stik6shift93's Avatar
If you have the msd iginition, you can run their retard module. i think you can find it a jegs it's like 90 bucks.
Old Mar 6, 2003 | 09:49 PM
qwick_trip's Avatar
is there any other way to do that because i don't know if i can come up with another $100. i have spent over $7000.00 total for performance parts already this winter!!!!!!!!!!!!!!!
Old Mar 7, 2003 | 03:56 AM
texlurch's Avatar
If you are running the stock computer timing, you can run a 100 shot safely, providing it doesn't go lean. Just make sure you run nothing but premium gas.
I would recommend running a bottle thru, and then pull your plugs and look for any signs of detonation.
Old Mar 7, 2003 | 11:46 PM
qwick_trip's Avatar
i got a msd ignition. probably going to be runing atleast 125 shot. is the only way to pull timing is using the msd box for that!!
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
