Voltage Regulator Replacement
Old Mar 5, 2003 | 09:25 AM
sdodd's Avatar
All,
Based on intermittent output during the bench-top test I believe my voltage regulator needs to be replaced. The alternator sat for 3 years in an "in-progress" project car without being used. However, it only has 40,000 miles on it. The bearings seem fine, but I never get ANY alternator output that I can measure when the car is running.
I took apart the alternator case and removed the voltage regulator. The new voltage regulator that I have has two metal studs. The old regulator has crimped/soldered metal connections to these studs. I can't seem to remove the connections from the old regulator. The crimping/soldering holds it too tight to remove, even with heat. Any ideas?
thanks,
simon
simon.dodd@hp.com
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
JSK333
Sep 9, 2002 10:33 PM
