the 100nx shot
ok guys well i have kinda aksed this ? befor but i have benn runnign the 100shot for few days now and then i hit it it really dose not fell like much i hear people talking about how it give u a good kick has any one here used the nx 100 shot and could fill me when what it should feel like thx alot every one...
I know you mentioned before that you didnt know the bottle pressure. Ok... then whats the approx bottle temp when you've tried to spray. Are you running a bottle warmer? Low bottle temperature will = low pressure, even with a full bottle. Your system would be extremly rich with a cold bottle and cause a huge power loss.
fhjmh
You need 1000PSI in the bottle
Starting with a FULL bottle is good
MAKE SURE you are using the reccomended jets for a 100 shot
Make sure everything is wired properly
Test the Nitrous solenoid with the bottle closed in your garage
Test the fuel solenoid while driving. Arm and engage the system while accelerating slightly. if that car nearly dies, shut the system off..it works
Open the bottle with it's 1000 PSI and activate the system at full throttle.
I don't know if you're using a throttle switch or rocker switch or a button. Goodluck. and throttle switchs are COOL. I suggest you get one and wire it up.
You WILL feel a 100 shot
Re: the 100nx shot
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
