Dual bottle ?? with a single stage
Old Mar 4, 2003 | 11:32 PM
JodyJ's Avatar
I'm thinking about adding a second bottle to reduce the pressure drop while shooting a 150-175 of nitrous.
My question is, if both bottles were heated to 1000 psi each using a water tank, then mount the bottles in the car using two 12" lines into a y fitting, then into a single 17' line to the nitrous soleniod. Would that make the total 2000 psi? Assume I could fatten up the fuel side. Would the NX nitrous solenoid fail to open because of the pressure?
Thanks,
Jody J.
Old Mar 4, 2003 | 11:49 PM
LPEdave's Avatar
No, you'd still have 1000psi. It just wouldn't drop as fast as with one bottle.
Dave
Old Mar 5, 2003 | 12:37 AM
JodyJ's Avatar
That's what I needed to know.
Thanks, Dave
Jody J.
Old Mar 5, 2003 | 03:41 AM
sideways_Into_3rd's Avatar
2x the volume, same pressure ..
volume and pressure are 2 separate issues...
say one of ur bottles was at 1000 psi .. and the other one was at 0 .. both would level each other off at 500 psi as half of the gas from one would go in the other till both sides of the y connection are at the same pressure (with a closed solenoid)
Old Mar 5, 2003 | 10:45 AM
JodyJ's Avatar
Thanks Sideways!
G-BODYT56
Jan 14, 2022 11:14 PM
football4life
Oct 4, 2015 07:48 AM
RX Speed Works
Oct 1, 2015 10:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
