Odb1 connector!
Old Mar 4, 2003 | 08:04 PM
94YellowTAGT's Avatar
Odb1 connector!
I was given a cable for my lt1 edit setup. The cable is for the odb2 cable. can these be modified to fit. also i have a actron code scanner and it is for the 94 connector. Can i make this fit with my wires? Thank you
Old Mar 4, 2003 | 08:38 PM
RiceETR96's Avatar
No it cannot fit. OBD1 ports are 14 pin ports. OBD2 is a 16 pin port. Only exception to that is the 95 OBD1 cars where they used a 16 pin OBD1 port
Old Mar 4, 2003 | 08:41 PM
turbo_Z's Avatar
the port isnt really and OBD1/OBD2 thing. its a 93-94/95-97 thing. so you just have the older port but still OBD1. you needed to specify you have the 14-pin connector instead of the 16 when you bought the cable.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
