gear whine?
Old Mar 4, 2003 | 06:29 PM
chpmnsws6's Avatar
gear whine?
so do all aftermarket gears whine?????? i'm thinkin about getting a set but i don't wanna hear em. if the parents hear em, they will take the car to the shop and BANG, warrenty VOID. can't let it happen so i was wondering how loud they are?????
thanks,
mike
Old Mar 4, 2003 | 07:06 PM
2000TA's Avatar
if they are put in right they wont make a noise. and Gears should not void the warrenty if anything just on the Rear end
Old Mar 4, 2003 | 08:41 PM
Gossco95's Avatar
ive posted this before ..... so here comes the copy and paste
Ive had a gear problem with my 95' camaro i drive right now, the mechanics from GM shop said that the gears will continue to whine until you replace them. Mostly cause they are not meshing right. So if its a whine the only way u can get rid of it is to replace the gears. I could hear my gears whine when I hit the gas and speeds up by 40 mph... luckily my car was still under a extended warranty and got the gears replaced my a certified GM dealer for about $1500. Which through the warranty I "thankfully" had to pay a $50 deductable + fluids. If its a constant noise around all speeds its more than likely a bearing problem (Yes ive had the bearings replaced about 3 months before I had the gears replaced.) But if its more of a stop and go noise try looking at the U-joints. Hope this helps.
Old Mar 4, 2003 | 11:37 PM
Ghost SS's Avatar
If you go to a 3.73 or steeper gear it will whine...plain and simple. It isn't that noticeable though, mostly on deceleration.
Old Mar 4, 2003 | 11:44 PM
stik6shift98's Avatar
my buddy has 3.73 and u cant hear em.......so i would only go to 3.73
Old Mar 5, 2003 | 12:13 AM
GrdLockV6's Avatar
Some gears will whine despite if they're set correctly or not. Higher ratio gears (3.73+) USUALLY whine a bit. Unless you're LISTENING for it though, you won't notice it most likely, so I doubt your parents will ever tell.
HarleyZ28
Oct 5, 2015 06:23 AM
CARiD
Apr 8, 2015 08:08 AM
737drivr
Feb 20, 2015 11:54 AM
ddr698
Jan 9, 2015 10:05 AM
Jessie4tin
Jan 7, 2015 08:53 AM
