check engine after cat back.
Old Mar 4, 2003 | 05:35 PM
Severous01's Avatar
i recently installed a catback totl system from slp, and afterwards, the check engine light came on. has anyone had to reprogram their ecu for a catback? also, i installed a slp cai soon after. i thought these bolt-ons would be safe for the computer. any ideas?
i dont have a daignostics scanner, and dont have the 100 bucks to get a new one. anyone living near burlington nj with a scanner and wouldnt mind helping me?
Old Mar 4, 2003 | 06:26 PM
Anderson's Avatar
Go to auto zone if they have one near you. Free checking.
Old Mar 4, 2003 | 06:36 PM
EviLBoX's Avatar
Is your car OBDII (96+)? If so there's a small chance it could be and EGR flow malfunction (code P0400). This occasionally happens to us OBDII guys when a free flowing exhaust is installed, but normally only after headers or removing the cats. It happens because the EGR functions off exhaust backpressure, so when the backpressure is reduced significantly, the EGR doesn't work properly. This does not happen to everyone, so it may not be your problem, but just an idea. Have your car scanned...
Old Mar 4, 2003 | 06:39 PM
ram air camaro's Avatar
check your o2 sensors thats one possibility!
Old Mar 4, 2003 | 06:49 PM
Jcb890's Avatar
go to autozone, which i need to do myself...i have an "SES" and a "BRAKE" light on and dont know y either one of them is there....
Old Mar 14, 2003 | 09:33 AM
Severous01's Avatar
the code was a p0410 code- iat sensor maofunction. what is a that? i know it is emissions control, and where it is, but is it worth fixing? what does it do?
Old Mar 14, 2003 | 09:38 AM
EviLBoX's Avatar
That's the intake air sensor, it's located on the air intake elbow. It's probably just a coincidence you got the SES right after the catback install, I can't think of how it would effect your IAT sensor. I'd just check the sensor, make sure it's plugged in, and maybe replace it. I haven't had a problem with mine, so I don't definitely know what could be wrong with it.
Old Mar 14, 2003 | 09:41 AM
faded93bird's Avatar
yes it is
it tells your ecm what temp the incomeing air is and has some control over timing
it is what plugs into the intake bellows on the passenger side
Old Mar 14, 2003 | 09:53 AM
Severous01's Avatar
i left it off when i installed the cai(forgot i did it later that day) i had to put it back in place, and everything is fine. the code corrected itself.
thanks guys, i appreciate everyone's help
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
