abs and e-brake light
Old Mar 4, 2003 | 03:41 PM
ip305's Avatar
Angry abs and e-brake light
ok my abs and e-brake light are both on but when i step on the break and start the car the will go off until i release the break. ive already had my mechanic pull the codes on it and it was sayin that one of the relays/ or the fuses were not working. but he ran a test on them and they appeared to be workin fine so right now im pretty much cluesless. all the brake lights are on and the the toggle switch for the e-brake is working from the tests ive done on it. any advice would be greatly appreciated.
Old Mar 4, 2003 | 07:36 PM
ip305's Avatar
ttt
Old Mar 6, 2003 | 04:57 AM
badass383's Avatar
We need to know the codes. I had a code for months. Finally spent some time tourbleshooting, turned out to be a bad BCM. Dealer cost as high as $700.00 Went to a local Junk yard and got one for $25.00 The point is the code said one thing but when tested it was ok so only thing left was BCM. Won't know yours until we know the codes.
grabbem88
20
Dec 27, 2015 07:42 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
