ATI super Damper Install question
Old Mar 4, 2003 | 12:33 PM
supermo26's Avatar
Unhappy ATI super Damper Install question
I have the ATI damper and hub assembly. It comes wiith 2 washers. One looks like it is used to hold the hub to the crank but I'm unsure about the other washer that has the key way. I don't have any directions so I need your help. Where does the Keyed washer go?
Old Mar 5, 2003 | 01:23 PM
supermo26's Avatar
ttt
Old Mar 7, 2003 | 07:42 PM
supermo26's Avatar
anyone have an Idea where the washer goes?
Old Mar 7, 2003 | 08:32 PM
LPEdave's Avatar
It's most likely a spacer to take up the space where the reluctor ring is, in the '96-7 cars. So if you have a '96-7, you don't need the ring, but if you have an earlier LT1, you need to put it on the crank behind the hub. I've never done that - I'm not sure exactly how it goes and stays on.
Dave
Old Mar 8, 2003 | 09:41 AM
supermo26's Avatar
So it will sit right up aginst the front seal of the crank?
Old Mar 8, 2003 | 11:45 AM
LPEdave's Avatar
Yes, but I haven't used it myself. The instructions on my Fluidampr say to "use it behind the hub". So basically it sounds like it'll just space the hub out 0.093"
Dave
Old Mar 8, 2003 | 03:14 PM
Joe Racer's Avatar
James,
It is sandwiched between the timing gear and the hub, and as mentioned, isn't used in an OBDII application. You can put a little vaseline on one side of it, and push it back against the timing gear with a small screwdriver. The vaseline between the gear and the washer will hold it in place while you install the dampner.
Man, I figured you'd be out burnin' up the road by now....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Deadbolt24
Jan 19, 2015 01:29 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
