Centerforce Clutch ????
Old Mar 4, 2003 | 11:26 AM
stylingxtremed's Avatar
I've got a 97 Formula that is about to have between 425 or 450 to the rear wheel. I need to know what clutch I should go with. I've heard about a few people having problems from the Centerforce Dual Friction and was looking for the best clutch for the job. Street Racing ofcourse.
Old Mar 4, 2003 | 11:43 AM
IDOXLR8's Avatar
My recommendation would to be do it right the first time and to go with a McLeod Street Twin. No need to waste your money with other clutches such as Centerforce.
Old Mar 4, 2003 | 01:22 PM
hsyr's Avatar
If you got $$$, get the Street Twin.
If you don't got much $$$, get a Spec Stage 3 Ceramic. Thats what I got.
Old Mar 4, 2003 | 01:58 PM
Laymaster's Avatar
I hear a lot of 'horror' stories from reading this board about the centerforce clutch. Corvette guys like them, however they tend to break apart in f-body's.... Something about the way it's manufactured for the F-Body. *shrug*
Old Mar 4, 2003 | 02:07 PM
PumpkinKingZ28's Avatar
how much different(if any at all) is the spec stage 2 clutch to the spec stage 3 ceramic?
Old Mar 4, 2003 | 02:11 PM
snksknr94's Avatar
Don't get a centerforce. Mine is coming out on Thurs. and being replaced by a McLeod street twin. Do it right the first time and go with the McLeod.
Old Mar 4, 2003 | 02:35 PM
stik6shift93's Avatar
Go with a stage 3 ceramic, don't mess with centerforce.
Old Mar 5, 2003 | 09:02 AM
Highlander's Avatar
I've had no problems with it... It will probably slip once I put full timing and 500rwhp are punched... we'll see...
Actually ... is there any replacement disc that is better than the centeforce but still uses the same pressure plate???
LMK
Old Mar 5, 2003 | 12:29 PM
InjectedSS's Avatar
neways.. i dont know where u guys get this about the centerforce being junk seriously ive had mine for about a year now and well over 20000 miles and ive beat the SH*T outa that thing ang its still holding well.. ive sprayed outa the hole before with mickey thompson et drags and that clutch ahs not cried about it ONCE however i do agree that it is NOT WORTH THE MONEY i did get mine brand new for like a $100 from a buddy so if i had to do it again i would get a SPEC clutch
Old Mar 5, 2003 | 06:45 PM
Highlander's Avatar
Mine hasn't cried either... but I had only 400rwhp.. no I think I should have 500rwhp... I will see if it holds up...
Old Mar 5, 2003 | 06:52 PM
95 Z/28 LT1's Avatar
Super Moderator
The Centerforce Dual Friction disc is actually pretty weak IMO. It uses stock friction material on one side, and they cut up stock material and put it in pieces on the other.
The pressure plate design of adding the weights to make more pressure on the disc via centrifical force is debatable on wheter or not it actually does anything or not.
Many people have had problems with their stuff on this board. Doa search for Centerforce and see what you come up with.
Old Mar 5, 2003 | 07:29 PM
Highlander's Avatar
I did a search...
Old Mar 6, 2003 | 12:45 AM
sc1twntrbo's Avatar
just helped a buddie pull out his centerforce... yep looked like a piece to me. no offence jason. i wouldnt buy one
Old Mar 6, 2003 | 12:59 AM
WJH'sFormula's Avatar
SC1 is talking about mine...
blew out a few weeks ago and finally pulled it tonight...the disc material on the pressure plate side just completely broke apart in a 5" section. i can take pics if you dont believe me. btw, the clutch has less than 30k miles on it, w/ only 3k miles on the heads/cam w/ less than 400rwhp
moral of the story: Centerforce = P-O-S!
im sorry, but IMO, street twin is a waste of money and overkill for my setup. a buddy of mine w/ a 440 rwhp LT4 Vette has been using a stock clutch for years w/ out problems...
Old Mar 6, 2003 | 04:15 AM
louvit's Avatar
clutch
I just put in a borg and beck anyone ever hear of that brand. It seems to release high and doesn't bite the way I'd like it to. But then again it's hydrolic!!!
