SES Light and misfiring
Old Mar 4, 2003 | 05:20 AM
zfastcarz's Avatar
Talking SES Light and misfiring
My friend has 98 Z28 and just recently the car started misfiring or something like it and the SES light comes on when this happens. He took it by autozone last night and they said it was misfiring on 3 cylinders and told him to replace the plugs. I thought maybe it could be his coil packs, is there a way to check these with a ohms meter and what should they read? He said it just started and comes and goes. We work nites so I'll be checking back on this later. Any replies are greatly appreciated.Thanks
Old Mar 4, 2003 | 05:25 AM
Ghost SS's Avatar
I do not know how to check the coil packs, but if it is coming and going checking them probably won't do any good since the problem might not be occuring when you check them. I also doubt it is the coil packs....they are very well designed.
I would say the plugs are bad...
Old Mar 4, 2003 | 08:16 AM
stik6shift98's Avatar
does he have nitrous????
he might have a bent push rod....
Old Mar 5, 2003 | 04:23 AM
zfastcarz's Avatar
No nitrous,bone stock daily driver with 88,000 miles.He didn't come to work tonite so I don't know if it died or what.
Old Mar 5, 2003 | 11:07 AM
goaliedave40's Avatar
Same thing happened to me. Dealer ran it across the diag. computer and said it was misfiring. They changed the plugs (113 euros for plugs...ouch.). No problems since. Good luck.
Old Mar 5, 2003 | 12:17 PM
Gossco95's Avatar
are the plugs wires correct on the distributor? thats if he changed them recently or the plugs themselves. I swear its the easiest of things that mess your car up. Or thats just my luck.... and i spend countless hours trying to figure whats wrong with it.
Old Mar 5, 2003 | 12:55 PM
ibanez6rg's Avatar
Not on an LS1
Old Mar 5, 2003 | 01:03 PM
damn your in germany.....how many fbody's are there....
Old Mar 6, 2003 | 06:12 AM
There are about 5 or 6 around here, can't say about other bases. www.fbodyeurope.org has alot of G.I.s on it. Not a whole lot of euro-spec fbods, though. Not exactly built for the small roads around here. (The autobahns are a diffrent story
Old Mar 6, 2003 | 03:44 PM
dkeers's Avatar
Just move the coils on the cyliders that are missing to 3 different cylinders. If the miss fire now appears on the new cyliders then the coils are bad. If the missfire stays on the same cylinders (with coils that are working) then you have another problem. Hope that made sense.
Old Mar 10, 2003 | 12:29 AM
i would kill for an autobahn......im registering at your lil board
Old Mar 10, 2003 | 07:49 AM
SheDevlLS1's Avatar
Same thing happened to a friends 00 SS yesterday- the car has under 28K miles on it. Was driving fine, then at a stop light it back fired a few times and the SES light began flashing...is at the dealership as we speak.
Old Mar 10, 2003 | 07:48 PM
MARSTAUT's Avatar
I'm having the same problem, It gets worse when I have the HPP3 engine tuning program on. I have changed the sparkplugs, I even tried a friends MAF to see if it help, it hasn't. What do ya'll think about it being an o2 sensor? this all started after I installed long tubes and a 3" true duel straights, I do have the o2 simulator in the back.
Old Mar 10, 2003 | 08:21 PM
try figuring out what cylinder it is and then switch the plug wires around....it can possibly be o2 or the 02 sims.....check out the sims and see if they are still there and are not melted or damaged...
Klypto
Mar 23, 2016 09:05 AM
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
