Valve Covers W/Compcams Pro Mag SA RR
Old Mar 4, 2003 | 03:42 AM
96BlkZ28's Avatar
I was wondering if the stock valve covers will support the Compcams 1:6 SA RR part number 1317-16. Do you have to cut the supports out from under the valve covers? What companies make centerbolt valve covers that are taller than stock but not the fab alum ones they cast like $300. Some pic's would help out if anyone has some of there set up.
Thanks Guys
Old Mar 4, 2003 | 05:35 AM
jkipp84's Avatar
I have Non S/A 1.6 Pro Mags, but I believe the S/A ones are the same size (anyone feel free to correct that).
A buddy of mine originally clearanced the stockers for me but I have since replaced them with the polished aluminum ones on Ebay that go for about $90. MUCH better. They're a nice addition (new bolts with allen wrench heads too), especially if you have your fuel rails and raised runners polished.
I did have to dremel out some of the supports on the new ones, but they are taller than stockers.. a really good deal IMO.
Old Mar 4, 2003 | 04:34 PM
96BlkZ28's Avatar
ttt
Old Mar 4, 2003 | 05:14 PM
Black95Form's Avatar
Stocker work fine. The webbing has a little flange to them. All you need to do is take some pliers and flatten them out as best you can. You may have to tweak here and there. Test install them as you go. No biggie. I have non sa pro mag 1.6 on my 355.
Michael
Old Mar 4, 2003 | 05:47 PM
96BlkZ28's Avatar
So you must have hardened push rods and guilde plates on your heads right.
Old Mar 4, 2003 | 06:21 PM
I am in the middle of a stroker build. I am thinking one engine and typing the other. My 355 has 1.6 Self Aligning Pro Mag rockers. Top of the line pushrods but no guide plates.
The stroker will have guide plates and non self aligning rockers.
Either way I beleive you will be fine. Although I have not tried the guide plates and non sa rockers with the stock covers yet. Very soon though.
Michael
Old Mar 4, 2003 | 06:47 PM
96BlkZ28's Avatar
Thanks for the info
it will help out
Old Mar 4, 2003 | 08:08 PM
JIMS1999CONVZ28's Avatar
RR and stock valve covers
Black95Form hit it correctly, yes stock will work.
I just want to add that I used a small pair of vice grips and you only do the long part of the webbing (stanchion) and roll the lip out straight. I then opened up my bendh vice jaws and flattened out the webbing so it was flatter, just move to the right then the left side of the vice to flaten it out with a small ball peen hammer. You could do this with a hammer and a pc of flat iron also. I just did this yesterday and you don't need to cut or bend the pvc baffle either.
HectorM52
Jul 30, 2017 11:46 AM
Roadie
Feb 16, 2015 10:34 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
