12 bolt guys??
Old Mar 2, 2003 | 10:59 PM
qwick_trip's Avatar
12 bolt guys??
ok i am going to get a moser 12 bolt rearend. i need to know what all to order such as
what gear 3:73 or 4:10
torque arm stock or aftermarket
driveshaft stock or aftermarket steel aluminum
what posi
and anything else that i forgot to mention please inform me on everything thanks
if it helps i have a m6 150 dry shot, hals complete kit, slicks, all the bolt ons possible. also if you got a price and were you got it. i am looking at a price of $2200 for everthing abs,upgraded yoke, 33 spline, upgraded cover. thanks
Old Mar 2, 2003 | 11:35 PM
94z'sson's Avatar
i would get either gear ratio
but i would look at www.spohn.net and look at their TQ arms
i would get a deny's 3 1/2" alum driveshaft
then a eaton posi
and then i would use BMR relocation LCA brackets (weld on)
Old Mar 5, 2003 | 07:49 AM
qwick_trip's Avatar
cmon guys!!!!!
Old Mar 5, 2003 | 09:02 AM
stewmeistr's Avatar
"ok i am going to get a moser 12 bolt rearend. i need to know what all to order such as what gear 3:73 or 4:10?
This depends on what you plan to do with your car? Do you want all performance or decent mileage? Deep gears are great with high winding cams with low bottom end power but are a pain in the a$$ to hook on a PA car..
torque arm stock or aftermarket?
I still have a stock TA but thats not to say that i wouldn't rather have an Aftermarket one. Becareful on this one because many people are not happy with some of the shorter TA's. Research this one a little more.
driveshaft stock or aftermarket steel aluminum? Again, depends on what you want to do with the car. The stocker is going to work fine until you get into major power and then you are going to want a Denny's to handle the big stuff.
what posi?
Eaton HD for a street car with some track duty.. The eaton isn't as buttery smooth as the stocker but it works well and won't leave you stranded. A locker is for the serious enthusiast imho
Get the HD cover..
if it helps i have a m6 150 dry shot, hals complete kit, slicks, all the bolt ons possible. also if you got a price and were you got it. i am looking at a price of $2200 for everthing abs,upgraded yoke, 33 spline, upgraded cover. thanks"
Seems like a good price. Thats about what i paid for mine but i didn't get in on a GP.. You might do better with a GP?
Shipping is expensive $2xx.00 or so.
Enjoy, should be fun.
STEW
Old Mar 5, 2003 | 10:52 AM
qwick_trip's Avatar
want a good set up for the track but also not to bad for the street.
i want to stay with stock torque arm
thinking 3:73 OR 4:10
3.5" driveshaft (whats better steel or aluminum)
eaton posi
i live right by ls1speed.com so i can just got pick it up so i wont have to pay shipping.
ALSO WHATS GP??????
THANKS
Old Mar 5, 2003 | 10:55 AM
DaveW 396ci's Avatar
With the moser remember you need a shorter drive shaft. Not sure what the recommendations are, but I think mine is about 1/2-1" shorter. Get a 3.5" Aluminum shaft.
If you are going to go with big cam and heads in the future and have a manual trans I would go with 4.10gears. Otherwise stay in the 3.xx range.
With regard to torque arm be ready to modify whatever you buy. I had to grind my mount point of the TA to the rear some and elongage the torque arm mount holes so it would mount to the Moser rear better.
DaveW
Old Mar 5, 2003 | 12:14 PM
mongse_1's Avatar
I've got my stocker that's cut to work w/ a Moser and a 4L60E. I'll also have my Spohn HD for the same combo available soon. They're both steel driveshafts.
If you're interested, shoot me an e-mail.
Old Mar 7, 2003 | 02:39 PM
stewmeistr's Avatar
Thumbs up
OH yeah, as mentioned. You will have to shorten the driveshaft from stock about 1".... I remember this now!!! THis was a reason why i couldn't go racing one wknd after the install.
You will have to modify the torque arm a little as mentioned as well. I'd just get all of the above aftermarket items installed at the same time.
More of My $.02,
STEW
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
transam_388
Mar 15, 2015 11:53 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Red97LT1
Aug 7, 2002 05:45 PM
