suspension advice
Old Mar 2, 2003 | 12:11 AM
rage366's Avatar
suspension advice
alrighty, i have a few bucks and i need to know what you guys suggest i should get to upgrade my suspension. i dont run at the track very often, so i need a setup that is designed for the street...
i have the stb. im thinkin about getting the double diamond sfc's...what else should i get?
please list your top three....thanks
--shokor--
Old Mar 2, 2003 | 12:15 AM
Bone Breakin's Avatar
sfc's are one of the best things to do. but you dont really need double diamonds, a set of boxed bmr's are all you need. if for street you mean you just want handling, lower it and get sway bars.
Old Mar 2, 2003 | 12:27 AM
rage366's Avatar
well, my car's already lowered. sway bars? my stock ones wont do, eh? well, reason i was thinkin about the DD's is cause i've heard they're better.
Old Mar 2, 2003 | 12:38 AM
i was told that the stock sway bars cant hold up to the potential your car has being lowered. as for the DD's i have been told by many that they were more trouble than they were worth. but wait and see what everyone else here says, thats just my opinion. I also recommend goin with BMR stuff for all your suspension needs. they make great stuff.
Old Mar 2, 2003 | 12:39 AM
i just read your tag it says you have edelbrock sfc. if you mean subframe connectors, then you should be fine in that department, i would go with the sway bars.
Old Mar 2, 2003 | 02:16 AM
rage366's Avatar
yeah, i've got the edelbrock sfc, i figured the DD's would be better. now, as far as the sway bars--any specific brand?
i pretty much want a set up that is really good...want that beeeyotch hugging the curves.
Old Mar 2, 2003 | 02:34 AM
SStupid's Avatar
Autocross
You want to carve corners? Then buy these: http://www.eautoworks.com/html/ORD-1-1-1-4470.cfm
The springs are linear-rate, so it makes for a more harsh ride on the street, but they're much more predictable than progressive-rate springs.
Of course, you'll want to get new shocks to go with them. The ground control coil-over setup only works with certain types of shocks. I know they work with Bilstein, so get those.
Old Mar 2, 2003 | 02:13 PM
rage366's Avatar
hmm, they look good. ok, what else?
so far, my DD sfc idea has been shot down. funny, no one has mentioned a panhard upgrade
Old Mar 2, 2003 | 02:40 PM
Dr.Mudge's Avatar
If this is with the intent of drag then check the drag forum, if this is for AutoX / RR duty then check that forum for better suggestions.
Old Mar 2, 2003 | 02:41 PM
rage366's Avatar
hmm, good idea, thanks doc.
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
jayblev95
Sep 26, 2015 09:44 PM
force10
Jul 30, 2015 04:56 PM
GT what?
Jul 14, 2015 10:17 PM
