quick question on cam install.
Old Mar 1, 2003 | 11:40 PM
bunker's Avatar
When the timing gears cam/crank the dots lign up as in the cam gear points to 6'oclock position & crank gear point 12'oclock postion is that #1 firing position of #6? Cuz I know when they lign up on the LT1 its #6, a little confused, thanx guys.
Old Mar 2, 2003 | 12:57 AM
stik6shift98's Avatar
is this an ls1?????
if yes go to ls1howto.com
if not post this at lt1tech
Old Mar 2, 2003 | 12:58 AM
NiteRider's Avatar
Bunker: Yes it is a LS1 so someone please answer my question.
Old Mar 2, 2003 | 01:05 AM
sleeperZragtop's Avatar
...did you guys secretly do an LS1 swap today....Armen, congrats on the car..sorry about your wallet. I can wait for my cam swap in the morning..
Old Mar 2, 2003 | 01:19 AM
did u try that site i gave you
www.ls1howto.com
Old Mar 2, 2003 | 04:41 AM
bunker's Avatar
yes I did, very helpfull, now question is, so the LS1 doesn't need a specific 0 lash rockers adjustment like the LT1 does? from what I understand, with the dots ligned just torque all rockers to 22 ft/lb & than turn the motor over 720*, than another 360* & than retorque to 22-24 ft/lb, so the rockers don't have to be off the lobes I guess? how does that work out????
Old Mar 2, 2003 | 04:57 PM
rick99ws6's Avatar
when cam gear points to 6'oclock position & crank gear points to 12'oclock postion, that is the top dead center position of cylinder #1
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
Noenav
Dec 6, 2014 07:35 PM
