Need help removing lower ball joint from control arm
Old Mar 1, 2003 | 02:33 PM
G's Z28-LT1's Avatar
How did you press the lower ball joint out of the control arm. Did you use a special tool? I've got the ball joint seporated from the steering knuckle but that's where i'm stuck.
Thanks.
Old Mar 1, 2003 | 03:12 PM
ZDriver96's Avatar
The ball joint press from napa is 200 bucks.. i checked yesterday..
My dad says he can get them out and put them in without a press. He tried explaining it but i wasnt really listening. I wonder if a 2 arm puller would work..??
TTT for yuh
Old Mar 1, 2003 | 03:27 PM
ball joints
Thanks for the reply, but I need specifics.
Old Mar 1, 2003 | 04:22 PM
Thomash's Avatar
Anyone I have done I used a ball joint press. I don't advise using a hammer. I doubt if you can get a 3 jaw puller on one. Autozone my have a press to rent. Or unblt the control arm and take it somewhere. You will need to align the car anyway.
Old Mar 2, 2003 | 01:43 PM
I went ahead and BOUGHT a ball joint press. Even with the "right" tool, it was still a pain in the *** to get the things out. Putting them in was even tougher. Job is done though, and I take it for an alignment today. Hopefully this resolves my continual alignment problems.
Old Mar 3, 2003 | 01:42 PM
White Z 4 Show's Avatar
I took a hammer to the top (which was a PITA!). One LBJ took about 1 hour of hammering the hell out of it and the other took over 2 hours. BUT it saved me from paying someone to do it (3 hours of labor). I would recommend putting the new LBJs in and immediately taking it to a place that does alignment and have them press it in and give you an alignment. I put new tires on my car about 5-6 months ago, did the LBJ install, I didn't have time to have them pressed so I went without them. I rotated my tires yesterday and a babies *** would be jealous of my front tires. It wore them to hell and back. BEFORE I get my Z06 rims and tires on I'm getting the best alignment ever done on a car. I can't afford to pay $368/tire b/c of a LBJ problem. Just my 2 cents
Old Mar 3, 2003 | 02:13 PM
1fast95Z's Avatar
I used a lot of PB blaster and a hammer and they came right out. However, if you look at the ball joints you will notice that they are installed with a slight angle to them. It helped me to unbolt the entire thing and then the ball joint would have a straightened path. Just patience and a hammer, and they will come off. They went back in almost effortlessly (I did not reinstall the original lower control arms, I used BMR's really sweet LCA's, makes the car handle soooo much better).
Disregard, I re-read the original post and I thought you were trying to remove the ball joint from the steering knuckle. My bad.
Old Mar 3, 2003 | 02:45 PM
BUBBA's Avatar
Big Hammer.
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
QuickSilver02
Apr 7, 2015 11:12 AM
thenewkid
Nov 27, 2014 09:41 AM
