how long to install shorty headers?
Old Feb 28, 2003 | 09:42 PM
Hyperspeed97z28's Avatar
I did my waterpump and opti myself in about 7 hrs, 1st time ever workin on my LT1 minus oil changes and brake jobs... I got dynomax shorties (95 style) with a borla Y-pipe, how long should these take to install and any tips or special tools I'll need, IM NOT USING AIR TOOLS EITHER>... should I soak the bolts in pb blaster or something the night b4? Thanks guys...
Keith
Old Feb 28, 2003 | 09:45 PM
Oh yeah I forgot to add that I'll be doin plugs and wires as well, tips for that? special ways?
Old Feb 28, 2003 | 09:53 PM
RamAir95TA's Avatar
Give yourself a long day if you've never done it before. I did my MACs in about 6 - 7 hours by myself. There's several install guides available with tons of tips.
I used this guide when I did mine: http://www.fastblackcar.com/camaro/mac_headers.html
Old Feb 28, 2003 | 10:09 PM
thanks man
Old Feb 28, 2003 | 10:32 PM
Bud M's Avatar
I'd plan on spending a weekend in the garage if I were you. The Dynomax headers should be really easy since you probably won't have to mess with the steering column and it should all bolt together. But you never know, things don't always fit perfectly...
PB Blaster is your friend, especially on those AIR/EGR fittings on the stock exhaust manifolds.
And route those plug wires so they don't get burned.
Old Feb 28, 2003 | 10:34 PM
RamAir95TA's Avatar
Look into an over-the-valve cover setup to prevent them from burning.
Old Mar 1, 2003 | 12:37 AM
1994TransAm's Avatar
it took me a *** load to remove my stock exhaust manifolds when i was putting in my edelbrocks. infact it took 20 mins to remove the driverside and 1 hour to remove the passenger side( i sawsall'd the y pipe and air! and started to unbolt the manifold.
to install my edelbrocks after i put the plugs back in (10 mins)and removed the steering linkage took me like 30 mins tops for the manifolds. the y pipe was harder but anyways!!!
Old Mar 1, 2003 | 12:47 AM
JKDZ28's Avatar
grrr im having a time with my install
be patient and take your time
Old Mar 1, 2003 | 08:27 AM
Hopefully all will go well, I might order my plugs,wires, stage 8 lockers and gaskets this week... I CANT WAIT. after that its intake leak time.... whoo hoo..... then CLUTCH... At least I got the cluch already though, SLP hehe
RUENUF
May 25, 2016 08:10 PM
dmcdonald96
Jan 30, 2015 06:46 AM
Jason Short
Jan 19, 2015 06:34 PM
Killer94z
Jan 13, 2015 12:06 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
