So, how screwed am I if.............
Old Feb 28, 2003 | 11:36 AM
XKnightRider's Avatar
I didn't know that the harmonic balencer on the LS1 is not keyed and I didn't mark the damn thing before I took it off!
Now what?
Old Feb 28, 2003 | 12:39 PM
Zdriven's Avatar
Not a problem!!
I work at GM Powertrain at the plant that use to build
the LS1 (Romulus). It is now built in St. Catherines.
The orientation on the balancer isn't important to engine
balance. Only on Manual Corvettes, where the engine
is balanced after assembly. The Corvette has a tighter
balance speck than the F-Body.
Just be careful to put it on straight, the hub is aluminum
and will shave off if you press it on crocked.
Old Feb 28, 2003 | 01:02 PM
Originally posted by Zdriven
Not a problem!!
Oh thank god....you are the perfect person to respond to this question! I was having nightmares of having to take out the crank and have the whole rotating assembly balanced again.
Does it matter that my car is manual 6-spd? I'll be really careful when I re-install it.
By the way do you have any documemtation on how to perform the re-install of heads, cam and intake etc. Where is the best place to find this info?
Thanks again, I can sleep better now!
Old Feb 28, 2003 | 01:19 PM
stik6shift93's Avatar
I'm guessing that its just on the vettes.
Old Feb 28, 2003 | 01:49 PM
Zdriven's Avatar
XKnightRider,
No, it dosen't matter that your car is a manual. Like I
mentioned earlier. The F-body balance spec is
.5 inch/ounce and the Man Vette is .25 inch/ounce .
I don't know the best place to get sevice info,
(ie head-cam install) I just know how we do it on
the assembly line. Its alot easier to do with the
engine on a pallet out of the car.
Old Feb 28, 2003 | 01:55 PM
Zdriven, have you heard of anything about cranks getting messed up after improper installment of the asp pulley. If so what goes on with that?
Old Feb 28, 2003 | 02:30 PM
XKnightRider,
Cool bro, thanks!
Old Feb 28, 2003 | 05:43 PM
Zdriven's Avatar
stik6,
I haven't heard anything about aftermarket balancers messing
up crankshafts. The only thing I could think of would be that
they weren't installed properly or damaging threads in the
crank. Sorry I couldn't help.
I do know it takes a lot of torque! If the bolt wasn't tight
enough the balancer could spin on the crank and damage it.
Torque spec: 50 N-m + 140 degrees.
That means torque the bolt to 50 N-m and then turn the bolt
an additional 140 degress. The resulting torque is usually
around 400 N-m or 275 to 300 ft/lbs.
Double check the spec though, don't take my word for it. I would
hate to tell you the wrong spec.
Old Feb 28, 2003 | 06:34 PM
poniekiller's Avatar
But keyed hubs are not a bad idea!
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Henson071
Aug 4, 2015 09:32 AM
Z28Freak86
Apr 28, 2015 10:35 PM
squarehead
Nov 21, 2014 08:02 PM
