Limit of the stock LT1 timing set.
Old Feb 27, 2003 | 04:50 PM
Javier97Z28's Avatar
Moderator
Hey guys, planning on the XE 224/230 cam, I also plan to pick up the GM Extreme Duty LT4 timing set due to wanting to keep my crank position sensor.
It is necessary correct? As far as I have been told it's not worth the risk to run a fresh stock LT1 set?
Old Feb 27, 2003 | 05:25 PM
stik6shift93's Avatar
It'll be fine as long as you don't spin it really high, keep it around 6200 and you shouldn't have problems
Old Feb 27, 2003 | 05:27 PM
FastGuyJR's Avatar
You'll be fine with a stock timing set, but for $250 why not go with the LT4 set? I did, and it was definitely nice seeing the difference between that and the stock set. Much beefier gears. I recommend using the LT4 Extreme Duty but many have used stock ones with no problems.
JR
Old Feb 27, 2003 | 05:40 PM
If I where to run a different timing chain I'd go with a double roller conversion, won't cost much more and you'll get some more power and durability from it.
Old Feb 27, 2003 | 05:56 PM
FastGuyJR's Avatar
He's not going to be able to go with the double roller conversion and retain his crank positioning sensor for OBD-2, since his car is a 97. Also, I believe he would need an electric water pump.
JR
Old Feb 27, 2003 | 06:20 PM
Moderator
JR
Correct, which is why, since I want to keep my CPS, I need to buy the Extreme Duty set if I want something beefier.
I actually do want the electric water pump but I'm going to have to wait on that one a bit since I can't really afford to get the WP and the double roller at the moment The water pump removal/install process is quick & easy for me so I don't mind doing it later.
I guess it's better to be safe than sorry, so I'll probably get the Extreme Duty
Any other opinions still welcome.
Old Feb 27, 2003 | 06:24 PM
WJH'sFormula's Avatar
eh, i use the stocker w/ no problems...
i spin mine to 6700 w/ the xe 230/236
i read that comp also made an LT1 timing set in a GMHTP a couple months ago...
Old Feb 27, 2003 | 06:27 PM
double roller=$70, csi pump=$140 so theres not really much difference in price and you get the benefit of the e pump. Sorry I didn't bother to look at what year you had.
Old Feb 27, 2003 | 08:37 PM
Joe Brodman's Avatar
GP Moderator
I had to make the decision of the LT4 chain or converting to the vented opti, E-water pump, and double roller.
I spent the extra money (my non-vented opti was almost new, though I DID sell it......) and went the cloyes double roller setup. No questions on strength there, and may have gained a couple HP in the process.
Old Feb 27, 2003 | 08:55 PM
NOMAD's Avatar
Cool
I actually moved from the Cloyes to a stock one. I was mainly having clearance issues and just didn't want to fool with it at the time. I'm pulling enough power to spin the crank hub on a NA engine and haven't had a problem yet
-Shannon
Old Feb 28, 2003 | 12:24 AM
GP Moderator
How did you have clearance issues? I did NOTHING special to install my Cloyes; I pulled the water pump drive and plugged the hole, but nothing else.
Old Feb 28, 2003 | 08:48 AM
Ken95Z28's Avatar
I had some clearance issues on mine.
I just used a high speed air disc sander and grounded about 40 thousands off the back of the timing cover.
I checked the clearance first without the gasket installed and made sure it clearanced it without any problems. And than when the gasket is installed there would be no problems for sure.
Old Feb 28, 2003 | 09:53 AM
NOMAD's Avatar
Cool
Well, mines a 95, so i'm not sure if anything is different. The first time I pulled the cover cause of some problems, i noticed it was contacting the timing cover. I left it alone and changed back over to the stocker when my GM pump locked up. That engine wasn't long for this world...lol
Wayyyyy too many problems
-Shannon
oldschool
Feb 9, 2016 09:21 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
siguy
Nov 27, 2014 10:07 AM
