South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
SLP day bracket racing competition... whos going?
Old Feb 27, 2003 | 12:57 PM
MustangEater82's Avatar
Anyone plannign on competeing in the bracket racing?
also do you guys know how it will be run? Its my first bracket race.
how is the tree gonna be, normal 3 light or the pro tree?
Old Feb 27, 2003 | 07:26 PM
mrr23's Avatar
i'll be in the elims.
Old Feb 27, 2003 | 10:08 PM
LT1Brutus's Avatar
I"ll be competing too. 10to1 odds says it'll be a 3-light tree considering the fact that most people will be out there just to have fun and aren't necessarily "drag racers"
Old Feb 28, 2003 | 01:20 AM
Does anyone know of any serious competition?
Liek peopel who do it every weekend? Honestly I am not sure if any 3rd or 4th gen f-bbody guys really do it, and don't really expect the vette guys doing it either.
and I still need a helmet
Old Mar 3, 2003 | 09:00 AM
gol10dr's Avatar
I'm going.. I think I'm just going to WalMart or Sports Authority and just buying a cheap BMX bicycle helmet to use. MY car doesn't run fast enough to need an expensive helmet.
BTW I'm most likely going out wednesday to see if i can at least get closer to consistant. I also just got a cut-out to.. I hope it helps alittle..
Gol10dr
Old Mar 3, 2003 | 11:22 AM
Will they care what type of helmet you use?
As for wednesday I am planning as well.
Old Mar 3, 2003 | 11:30 AM
LT1Brutus's Avatar
I do believe that according to the rules it has to be a Snell-approved helmet w/ a certification less than 2 years old.
Old Mar 3, 2003 | 11:42 AM
Gol10dr
Cutout ehh....
I been fiddling with some things... to try and win my money back. I think I cna take you easily on your old setup, but the new one, might have to do a few mroe things to get a gurantee.
Old Mar 3, 2003 | 11:43 AM
gol10dr's Avatar
Well It looks like a cat back will be coming soon. I don't think I'll have it on by Wednesday, but you never know.
Old Mar 3, 2003 | 02:15 PM
LT1Brutus's Avatar
If you want consistency make sure you've got great traction, your tranny is holding up well, install an electric waterpump along w/ a switch that activates the pump and fans while the car is in the staging lanes. Other than that, move your coil and ESC away from the location the factory has it in and make sure your plugs and wires are nice and youthful. Remember, quite often, unless on a professional level, slower cars are easier to make consistent.
Old Mar 3, 2003 | 02:33 PM
OutKast's Avatar
All great suggestions but I've never heard about moving the coil and I'm drawing a blank with the ESC (what is it?) Do you move the coil to a cooler location or iis it for another reason? If for cooling...where would you suggest moving it to? Pics?
Oh yea, I'll be there and should be in the lanes. See ya there!
Old Mar 3, 2003 | 03:20 PM
anasazi's Avatar
damn so you mean my 30 year old hand-me-down i got for free won't do?
Old Mar 3, 2003 | 06:43 PM
hehe oddly enough, I am planning on going in my everyday driving setup, not my track setup.
withe the competition, 3.4L will be the slowest course i still ahve to deal with my 5-speed.
Old Mar 3, 2003 | 08:48 PM
LT1Brutus's Avatar
OuKast, the ESC and coil are riveted together and mounted to the front of the head from the factory. If you've ever replaced a coil while the car has been running, or even 30 minutes later, you'll understand the heatsoak these go through. Well, over the summer, I had some codes that suggested that either the opti, coil, or esc had a problem, but it only started popping up the code and running bad after it got hot, so I took these out to have a look at them. While I was diagnosing the problem, I let the car run, w/ these sitting off to the side, and the problem went away. Right after I reinstalled them, it was back. I recalled back to my 3rd gen days that on the older 3rd gen the coils would get heat-soaked and you'd lose power. To make a long story medium-length, after experamenting, it turned out the ESC was starting to fail, but upon installing the new one and monitoring my timing, idle and 02 readings, it appeared that moving the ESC away from the heat cleaned up the idle "chop" that a lot of people complain about not being able to get rid of. There was a large thread, do a search, over the summer, where about 10 other people posted having tried it and having successful results. It saved one guy from replacing his Opti. I don't have pics but mine is now located right next to the fuse box under the hood.
Old Mar 3, 2003 | 10:07 PM
anasazi's Avatar
i think i might wanna try this... you going to the CFFB thing this weekend? i'd like to check out how you did it.
