LT4 Valve covers and Comp 1.6 RR Grind or no grind?
Old Feb 27, 2003 | 11:39 AM
supermo26's Avatar
I put the valve cover on the heads with out grinding out any supports. I have not bolted them down, just placed them over the RR till they sat on the head. I don't have a lot of room to slide the cover from side to side or forward and back.
I have seen the post on grinding the supports out but I am wondering if I need to or not since they don't seam to be bottoming out on anything. I don't want to grind tham down if it is not needed. Has anyone else had this happen to them recently? I don't know wether or not I shold grind them?
Old Feb 27, 2003 | 05:57 PM
TimChiaretto's Avatar
I didn't have any clearance problems with mine. Everything fit fine.
Old Feb 27, 2003 | 06:03 PM
stik6shift93's Avatar
I know of several people that haven't needed to grind them out, though I would just to be safe.
Old Feb 28, 2003 | 01:32 PM
supermo26's Avatar
I went to ace and got some washers but Im still not getting a tight seal around the cover. I bought 1/4 by 1 inch washes and I probably should of got the washer to fit over the stud to make it work the way I need it to.
No I have to have a threar repaired because the stupid hole was to shallow and I tightend it enought to mess up a threar or to at the bottom. I'm wondering how hard it would be to drill and tap the hole for the correct lenght? Any one know?
Old Feb 28, 2003 | 02:15 PM
Gripenfelter's Avatar
LT4 valve covers have more clearance I believe.
Old Feb 28, 2003 | 03:14 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
correct
and they kill some of the sound in the VT
Old Feb 28, 2003 | 03:39 PM
KenP's Avatar
The LT4 covers fit over my CC1.6 rr. No modification necessary.
nikolt1
Feb 27, 2015 09:10 PM
Roadie
Feb 16, 2015 10:34 AM
Jazsun
Dec 29, 2014 12:14 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
