whats the correct fuel press at idle
Old Feb 26, 2003 | 11:31 PM
red96z's Avatar
with all hoses hooked up and also is it bad to have bubbles in the gas when you purge the schrader valve.thanks
Old Feb 26, 2003 | 11:35 PM
drop top steve's Avatar
Fuel pres should be 43.5 +- 1.5 with vacuum line off, no you should not have bubbles.
Old Feb 27, 2003 | 12:40 AM
red96z's Avatar
my pressure was around 36 to39 with lines connected is that ok
Old Feb 27, 2003 | 09:34 AM
That does not sound too low. Pressure requirements are not as great when idling. If it goes up when you remove the vacuum line, you should be ok.
DirtyDaveW
Dec 1, 2016 05:37 PM
sloppytot
Feb 25, 2015 08:30 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
!!!TED!!!
Aug 27, 2002 05:41 PM
