my idle speed is 1k????
Old Feb 26, 2003 | 04:30 PM
cridom's Avatar
is that normal for a m6? 94z
Old Feb 26, 2003 | 04:35 PM
Buttercup's Avatar
I'm willing to bet it's just that your tach reads ~200 RPM high, which most do. To really know for sure, the easiest way to check on your actual RPM is to use a good scan tool.
Old Feb 26, 2003 | 04:38 PM
BUBBA's Avatar
Depends on Tach error. Most tachs on 4 gens seem to be 200-300 high. I believe that 950-1000 is fine, but if your tach is off by the usual amount you may be actually running around 700-800, which, in my opinion, may be too low.
Have someone check your "actual" rpm. JMHO
Old Feb 26, 2003 | 04:41 PM
Buttercup's Avatar
Stock M6 cars idle at 800RPM when warm.
What does the tach read at 60MPH in 6th gear? If it's around ~1600 RPM then it just reads a couple hundred RPM too high. I think mine read 1600 RPM but actual was about 1400 to 1450 at highway speeds with the stock 3.42 gears and tires.
Old Feb 26, 2003 | 05:15 PM
BUBBA's Avatar
You are probably correct on stock idle. I think the ideal idle is as low as you can idle smoothly.
I believe mine always showed around 1150-1200 on the tach. When I had small cam installed, I believe it was programmed to idle around 950. It still shows around 1100 on tach.
With the cam, I'm not sure it would idle smoothly at an actual 800, but a stocker might idle very nicely at factory setting.
So if your tach says 1k and your idle is smooth, I wouldn't concern myself about it.JMHO
Old Feb 26, 2003 | 05:31 PM
cridom's Avatar
mine says 1500 at 60 mph
or near 1600
thanks
Old Feb 26, 2003 | 10:51 PM
Dr.Mudge's Avatar
Yep, tach is not fully accurate. 800 RPM is stock, as noted, when warmed up.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
edman
Mar 13, 2015 09:39 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
edman
Jan 25, 2015 02:41 PM
