The most effective suspension mods
Old Feb 26, 2003 | 10:53 AM
5H9D0W's Avatar
I have a question about suspension mods.They can cost alot of money,I just want to know what to get in my situation.I want more power to the rear wheels off the line and don't really want to lower my car,but if it helps alot I will do it.I am leaning towards the 60' factor on the track.I have a TC,4.10,nittos and thats about it right now.any feedback would be nice
Old Feb 26, 2003 | 11:01 AM
95TA8280's Avatar
I'm going with a panhard bar, strut tower brace, lower control arms and sub frame connectors. They are typical suspension mods. You can also go with relocation brackets. Do a search, you'll find a lot.
Old Feb 26, 2003 | 11:04 AM
5H9D0W's Avatar
Are shocks and springs nescessary
Old Feb 26, 2003 | 11:05 AM
speedmiser's Avatar
Best thing you could do for your 60's at the track is go with a better tire (et streets, qtps, or slicks), a larger than stock stall (if you havent already), and spray it out of the hole.
Old Feb 26, 2003 | 11:08 AM
PatriotTA's Avatar
I think most people would agree, they are necessary. I am saving up for this right now.
Old Feb 26, 2003 | 11:10 AM
94SLUG's Avatar
I noticed some gain from control arms cheap too 125. Subframes are not a bad idea.
Old Feb 26, 2003 | 11:11 AM
5H9D0W's Avatar
Originally posted by speedmiser
Best thing you could do for your 60's at the track is go with a better tire (et streets, qtps, or slicks) and a larger than stock stall (if you havent already).
Nittos aren't good enough?
Old Feb 26, 2003 | 11:13 AM
TedH's Avatar
1. Et Streets
2. Disconnect front sway bar
3. Drag springs, shocks, and an airbag.
4. Lightweight front rims and tires
5. If you get into the 11's at an NHRA track you will need a roll bar. Do this instead of subframe connectors (save the weight).
Its all about the transfer of weight from front to back. Lowered cars are more difficult to hook up at low power levels. You want the driver side wheel to lift slightly. You want the rear tires to wrinkle.
Don't waste your money on a bunch of heavy duty components that add weight to your car until you have to do it. I still have the stock torque arm and have never had subframe connectors. I hook up just fine but the rollbar does help stiffen the chassis. My 60' times are high 1.5's and low 1.6's.
Old Feb 26, 2003 | 11:14 AM
speedmiser's Avatar
No, not if you want to juice it out of the hole with deep gears and/or a decent stall. I'm sure nittos would work fine on motor though.
Old Feb 26, 2003 | 11:15 AM
teke184's Avatar
first off, lowering your car will negatively affect your ability to lauch well at the track...so if yo want low 60' times, don't lower the car
mods that will help your launch will be subframe connectors to stiffen the chassis, lower control arms with relocation brackets, and an aftermarket torque arm.
you should at least look into the LCA's and brackets, BMR sells them for around $90 for the lca and thier brackets aren't bad either. these will probably give you the best traction boost.
if you don't want to spend the $300+ on a torque arm, at least go for a polygraphite bushing, about $15 from summit/jegs.
if you want to mess with springs/shocks, you can spend the money on drag launch springs and some drag shocks, or adjustable shocks so that you maintain some street manners. or you could go the cheaper route and get some V6 springs and your choice in shocks
Old Feb 26, 2003 | 12:23 PM
Gripenfelter's Avatar
Spohn Lower Control Arms and relocation brackets.
Airbag in the passenger side rear coil.
These three items will give you the most bang for your buck for straight line acceleration.
www.sybersport.com carries Spohn.
Email Darren at info@sybersport.com or call him at 204-254-4476 and tell him Grip sent you for the best possible deal.
BFG Drag Radials hook really well too.
Old Feb 26, 2003 | 12:33 PM
chesee48's Avatar
This is what my set-up will be:
Kenny Brown DD SFC
MAC Lca
Mac PHR
BMR STB
BMR Brackets
Hal Shocks/Springs Front/Rear
Old Feb 26, 2003 | 12:51 PM
Ben Ramsden's Avatar
Call Sam Strano and stranoparts, he will tell and explain to you anything you could ever want to know about suspension. I talked with him for over an hour, he explained to me how some/most of the sh** people tell you to do on here and other sites is not correct, depending on what other mods you have and the type of driver you are and roads your driving on. He takes all this into consideration, then recommends something.
After speaking with him I have decided to go with BMR stb, kbdd sfc's, bilstein HDs, Eibach Pro kit, 35mm front sway bar, polygraphite bushing front rebuild kit, and rear sway bar bushings, custom CNC machined 6061 T6 aluminum LCA's and Panhard bar. Haven't decided on relocation brackets yet.
Good luck.
Old Feb 26, 2003 | 04:20 PM
BigRich's Avatar
Not if you only care about going straight.
Old Feb 26, 2003 | 04:23 PM
STB and lowerings springs can hurt your straight line acceleration.
Panhard bar is only to center your rear. Won't help with straight line acceleration.
