quick question????
Old Feb 24, 2003 | 11:03 PM
qwick_trip's Avatar
Question quick question????
ok i removed the air pump and tubes. on the bottom of the air pump was a wire connector, i unplugged it, it lead to a small cylinder shaped plastic peice, then off that peice there are small rubber tubing that leads to the driver side of the intake and wraps around the the rear of the intake were there is a circular metal peice were it plugs in one side and out the other side and leads to the passenger side of the intake. do you understand what i and talking about. can i just unhook all of that and plugs the hole's hooked to the intake???
Old Feb 25, 2003 | 07:33 AM
qwick_trip's Avatar
come on some ones got to know. the small rubber lines with boots on the end. there about the diameter of a pencil.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
