swap from unvented opti to vented opti??
Old Feb 24, 2003 | 12:30 PM
TMDZ28's Avatar
is this possible?? if it is, how hard is it? i believe my water pump is leaking, so i need to replace it, also i think my opti has gone bad due to a leaking water pump......so please tell me how to swap from the unvented to vented opti...thanks in advance
Old Feb 24, 2003 | 12:37 PM
AlexA's Avatar
You need :
95+ timing cover
vented opti
air lines
new electrical connector (the connector is longer)
I've done it on my 94.
-Alex
Old Feb 24, 2003 | 12:38 PM
TMDZ28's Avatar
how much is the overall cost to do this?? would it be worth me money though?? thanks man
Old Feb 24, 2003 | 01:45 PM
TMDZ28's Avatar
ttt for me
Old Feb 24, 2003 | 01:49 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
if you dont, just rest arrured you will if you ever have to do it agian.
they are discontinuing the non vented opti
with that said, its a great time for an LT4 hot cam since you have to pull the cam anyway
Old Feb 24, 2003 | 01:50 PM
IDOXLR8's Avatar
Well if you are going to replace the opti you might as well do the conversion. Should cost you around 600 to do the conversion.
Old Feb 24, 2003 | 01:51 PM
DjArcadian's Avatar
trey, where did you hear they're discontinuing the non-vented opti's?
Old Feb 24, 2003 | 01:53 PM
atljar's Avatar
350 parts if ordering from jason cromer to convert to 95+ vented opti
Old Feb 24, 2003 | 01:54 PM
treyZ28's Avatar
I met up with a vette forum guy who had a non vented opti.
he was telling me how he bought 2 when he was doing his Lt4HC and rebuild
he said they were discontinuing it
Old Feb 24, 2003 | 01:56 PM
You actually believed someone in a 'vette forum?
Old Feb 24, 2003 | 01:58 PM
TMDZ28's Avatar
the only problem here trey is i dont have enough money
Old Feb 24, 2003 | 01:59 PM
treyZ28's Avatar
hahaha
he seemed like a pretty cool kid,
not yet bastardized by their old school know it alls
(I only feel for the poor guy they convinced to get 22lb injectors for his 383 with radical cam and heads . Ehh i tried, they said i was a dumb *** camaro kid and i would gain 1/2 a sec by going to 24lb injectors )
Old Feb 24, 2003 | 02:01 PM
IDOXLR8's Avatar
Oops I was taking into consideration the price of the electric waterpump.
Another option would be converting over to Ls1 Coil Packs using the LTCC box.
Old Feb 24, 2003 | 09:30 PM
atljar's Avatar
Ya 350 parts for just opti stuff, but while your at it go electric h20 and cloyes true roller chain That will put you at his 600 mark.
Old Feb 24, 2003 | 09:47 PM
Blk94Z28LT1's Avatar
i doubt GM is discontinuing the non-vented opti. If they do , they will have to come up with a replacement part. And it would be a direct bolt on part, no modifications.
