help with coil and igniton?
Old Feb 24, 2003 | 10:41 AM
qwick_trip's Avatar
Question help with coil and igniton?
ok i got a 95 z. i am putting on a msd blaster coil part#8226, msd 6a ignition and msd wiring harness part#8876. ok i am running it to some trouble. my first question is when i took my stock coil off there was a bracket mounted to the coil that had a wire connection to it. the directions say nothing about removing it from the stock coil but if i leave it off there will be an open connection on my car. second question on my msd coil there is two conections and the harness that i got plugs into the factory wire right but the part that plugs into the coil it leaves half of the plug open and that what the diagram shows but is tht right to leave a comection open on the coil, but when i look at the diagram in the msd ignition booklet it shows to splice the wire and then the two conections are pluged but i don't have that plug or don't i need it. i called jegs and msd and they were not sure.
Old Feb 24, 2003 | 10:55 AM
96cam4ro's Avatar
Not sure about the wiring because I have a single connector setup, but you will need to drill those rivets off to get the coil out of the bracket. Did it last saturday.
Old Feb 24, 2003 | 11:41 AM
qwick_trip's Avatar
ok so i need to take that peice off right? then mount it to the msd coil! ok now what about the conector on the coil one sides stays open?
Old Feb 24, 2003 | 12:08 PM
anaik's Avatar
When I installed the 6A with harness to my stock coil, it left one of the connections to the coil open. Is the MSD coil exactly like the stock coil? I wouldn't splice a connector for the other side.
Old Feb 24, 2003 | 12:27 PM
qwick_trip's Avatar
right, i just needed to know if it's ok to leave that one side open!
Old Feb 24, 2003 | 03:00 PM
It should look like this when you are done. One side of the coil does not get a connector with the #8876 harness. The other single row, four wire connector is for the ignition control module that must remain plugged in.
Old Feb 24, 2003 | 04:15 PM
mkent's Avatar
i'm just reading in and trying to learn here...is this good for any kind of performance gains?
Old Feb 24, 2003 | 04:23 PM
Maybe not so much if you are not spraying or blown. The multiple spark is more beneficial under those circumstances. Just adding an aftermarket coil could provide some benefit to a pre 1996 car, since the older stock coils were said not to be much more than "adequate".
Neither of these things is something you might feel, but sometimes the MSD does add a little smoothness as some have experienced. I think it depends on the state of your existing plugs and wires as to what you might feel after install. A slight increase in gas mileage is a possible benefit.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
