Anyone have a flow sheet on non-ported LT-4 heads?
Old Feb 24, 2003 | 03:46 AM
SStupid's Avatar
If anyone has this info, I would really appreciate it. GMpartsdirect is selling the LT4 heads for $615/head, fully assembled, so I was looking for a flow sheet to compare them with the AFR heads. thanks a bunch.
Old Feb 24, 2003 | 05:40 PM
jmzlt1's Avatar
Check on www.ws6.com and click on the links section. Go to David Chernicoff's blown t/a all the way at the bottom. On his website there is an interesting comparison between different heads. Hope this helps.
Old Feb 24, 2003 | 05:47 PM
Grease's Avatar
This should help you,
http://www.malcams.com/legacy/misc/headflow.htm
Old Feb 24, 2003 | 05:53 PM
Dr.Mudge's Avatar
Hmm, about $300 more and you could get a set of heads fully ported and setup for the cam of your choice, where the LT4 heads will come with springs suitable for .525" lift or so only.
Old Feb 24, 2003 | 09:21 PM
SStupid's Avatar
Thanks guys, that helps a lot. Hey, Doc, could you elaborate more on the $300 statement. Is that per head or per set? Where, and what kind of heads. Thanks. Always looking for the best deal. I only currently have 1200 to spend due to tax return, but I guess I can keep saving if there is a better deal out there.
Old Feb 24, 2003 | 09:37 PM
Timberwolf's Avatar
Scoggin-Dickey has CNC ported LT4 heads "version 2" for $1082 each fully assembled. But they have flow numbers, and I've seen LT1 heads ported to flow more with stock valves even
Old Feb 25, 2003 | 01:55 AM
Dr.Mudge's Avatar
Per set, you can find head work places for less than that, fully rebuilt, but I have no experience with "budget" head stuff. I payed around $1500 for heads, fully rebuilt, helicoiled (dont leave home without em), etc
Old Feb 25, 2003 | 01:58 AM
Dr.Mudge's Avatar
Unfortunately all CNC means is they copied a hand port (most likely), or programmed in some info without touching the heads with a hand port job (less likely). I'm sure you knew that, I just want to remind people CNC is nothing to go ga-ga over, CNC can be either great or not so great, on in between more often seems like. I dont think I'd buy LT4s unless I was going to hog the crap out of them, even a budget set of ported LT1 heads would be less expensive, and not require the LT4 intake.
Old Feb 25, 2003 | 09:13 AM
LT4POWR's Avatar
Where at on this site??? I couldn't find it.
Old Feb 25, 2003 | 09:36 AM
SStupid's Avatar
Cams
I found only a cam comparison, but thanks, anyway. I think I like the LT-4 heads. I like the fact that they're factory GM.
Old Feb 25, 2003 | 09:53 AM
97Z-M6's Avatar
Re: Cams
get you a set of lt1 cast and get loyd to port them for you. and he will make those heads perform. way better than stock lt4 and for not much more you can get the lt4 for. jmho
Old Feb 25, 2003 | 10:17 AM
BAD 97 WS-6's Avatar
Great Chart!!
Old Feb 25, 2003 | 04:40 PM
jmzlt1's Avatar
It used to be under the dyno results page. The link doesn't work anymore(I just checked). Lucky I copied the info when I first saw it! His stock lt4's flowed, intake/exhaust .100- 56/47 .200-119/102 .300-179/140 .400-218/164 .500-241/176 .600-232/182 Then he had them ported by gtp and got intake/exhaust .100-66.9/56.7 .200-137.5/112 .300-193.5/148.4 .400-236.3/183.7 .500-265.5/198.9 .600-280.2/208.1 These heads were done a couple of years ago. I've heard that people have not been getting good results from gtp recently. Hope this helps a bit. Sorry for the bad link.
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
