Car Revs slow, What to check?
Old Feb 23, 2003 | 11:24 AM
rickyzZ28's Avatar
When I rev my car through the RPM range the car feels like it revs very slow. It just doesnt feel as though it is running right. Would a rich condition cause this, or is there something else I should check? Opti, plugs, wires are brand new. The car just feels sluggish is there anything to check out that could make it rev smoother. I have also checked the TPS and it is well within spec.
Old Feb 23, 2003 | 11:35 AM
Dan95TA's Avatar
when my fuel pump was starting to go out i noticed my car would sometimes rev very slowly and cause a power loss. that was only when i was driving it, I think it reved ok when it was in neutral.
Old Feb 23, 2003 | 12:35 PM
funina91ss's Avatar
you could check the cats if they get cloged it will rev slow.
Old Feb 23, 2003 | 01:13 PM
snakeatinZ's Avatar
Ditto!!!! Check this before anything! I had the same symptoms, removed the cats and replaced them with an off-road y pipe, problem salved!
Old Feb 23, 2003 | 02:51 PM
ChickenScreamer94's Avatar
your sig says you have exhaust mods, did you get a LT4 KM? maybe you are getting alot of false knock with your exhaust causing the pcm to retard timing.
Old Feb 23, 2003 | 03:02 PM
D James's Avatar
cats are a good one to check, those will really slow you down if they're clogged. I had the same problem as you, my car reved real slow and it seemed like it just wan't fast anymore, although everyone told me it felt quick. well I started checking everything, and it turned out to be my throttle cable, the plastic piece in the front broke allowing the cable to slide forward and as a result the butterflies were only opening about 40%, after I fixed it, it was like I added 100 horses. So have someone push the throttle down all the way and check if they're opening up all the way
Old Feb 23, 2003 | 03:08 PM
94_formula's Avatar
the sig says its a 93 motor, could you get a lt4 KM for the 93 lt1??
Old Feb 23, 2003 | 04:49 PM
JKDZ28's Avatar
cant use lt4 knock module on the 93's
Old Feb 23, 2003 | 09:24 PM
rickyzZ28's Avatar
Well here is a little update, I have no cats, and no I have not desensitized my knock sensor. I will do that next. Also like said above I cant use the LT4 KM on the 93.
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
draven666
Nov 26, 2014 07:16 PM
draven666
Nov 26, 2014 07:10 PM
USAirman93
Nov 24, 2014 03:37 PM
