Relax, it's different kind of cam question.
Old Feb 22, 2003 | 07:44 PM
SStupid's Avatar
I understand that the best method for choosing a cam is to use your head flow numbers. My question is: how do you do this? How do you tranfer head flow numbers into a cam choice? Thanks in advance.
Old Feb 22, 2003 | 09:28 PM
Josh-'04 GTO's Avatar
While I think Fred or Rich etc. could explain better, I'll give it a whirl.
Your head flow numbers give you two important pieces of info. You find out the valve lift where you get peak flow, and you get the actual peak flow number.
The peak flow number will tell you what kind of rpms your heads can support on a given displacement. Knowing the rpm range you can support will help determine your duration numbers.
The valve lift where peak flow occurs should be where you attempt to have your cam lift ground. That way you are not opening the valves more than needed(past head stall point), but you're also not leaving power on the table by not having enough lift.
While there are more factors involved, that's it in a nutshell.
REDNECKISBOSS
Mar 22, 2015 08:31 AM
mongoose=
Mar 22, 2015 07:22 AM
carl.froehlich
Mar 13, 2015 12:38 AM
aj2494
Mar 12, 2015 10:17 PM
alex5366
Feb 17, 2015 09:07 AM
