Borla Exhuast Setup
Old Feb 22, 2003 | 05:51 PM
thelategreatz28's Avatar
Borla Exhuast Setup
Hey I wanna get the new borla pro xs muffler but its kinda weird so I drew something and im adding it here as an attachment... Tell me if it is right or how I would go about setting it up.
http://www.angelfire.com/alt/lt1exhuast/untitled.JPG
Old Feb 22, 2003 | 06:21 PM
Lions3's Avatar
Why not get a single in/single out muffler? Then just have a Y pipe on the exit side, one pipe for each side.
Or, do what I did and have the Y pipe before the muffler so you have one side open, one side muffled. Quiet at idle and moderate RPM's, LOUD at WOT.
Old Feb 22, 2003 | 08:17 PM
I guess, But I really wanted a single in dual out muffler becuase I already have single in single out that I dont like and I wanna borla. But why does the new borla pro xs muffler have a center inlet on one side and a dual outlet on the other side, its just plain stupid.
Old Feb 22, 2003 | 08:24 PM
funina91ss's Avatar
this seems like a muffler for a chevy truck or something where the muffler will be turned straight so the y pipe goes to the single in and the two exits go to the tips giving the dual look.... See if they make on that has inlet outlet on the same side...
Old Feb 22, 2003 | 09:03 PM
Lions3's Avatar
It's not designed specifically for Fbodies, that's why.
Either get a different muffler, or pay out the *** to have a custom bent pipe so you'll have dual outlets on either side.
Old Feb 22, 2003 | 09:51 PM
But I really want a borla, Where can I get a transversely mounted borla with outlets on each side.
Old Feb 22, 2003 | 10:00 PM
SStupid's Avatar
Catback
Your best bet would be the catback, of course, but I'm sure cost is the reason for the muffler. The catback is a single-inlet, single-outlet with one pipe coming off the primary before the muffler and going out the passenger side. With the "fully open" tuning plate, you're really not using the muffler at all. You could always consider running a two-on-the-left setup. I don't know if there would be room, but coming back over to the passenger side from the driver's side muffler outlet would be impossible. There's just not enough room. You would be able to see the pipe from behind the car. I got my Borla catback for $250 bucks, used. It was in nearly-new condition, so be patient and keep checking the "for sale" section for good deals. Good luck.
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
KYWes
Aug 10, 2015 07:03 PM
