Coolant
Old Feb 22, 2003 | 11:35 AM
Sterlingsxe's Avatar
Coolant
Ok guys i flushed my heater core or coolant a couple weeks ago to get my heat back. My car has been running a lil past 180 when i idle is that bad or normal? But it gets to like 200 but then goes back down im guessing that the thermastat opening. BUt the low coolant light goes on. I checked it and im deffinitly not low on coolant any suggestions to what this couold be? ANd A fix?
Old Feb 22, 2003 | 11:37 AM
RamAir95TA's Avatar
Your temperature behavior is normal. Low speed fans come on at 215, which would explain the drop in temperature.
And it's your low coolant sensor. It's a common problem on our cars. A replacement is relatively cheap.
Old Feb 22, 2003 | 11:39 AM
larson_lars64's Avatar
I can't tell you for sure but i think 180 is about normal. If you put a new thermostat in, most of them are 190 degree thermostats. I had the problems before that my low coolant light would keep going on and it turned out to be there was an air leak in the radiator cap. Maybe check your radiator cap for a good seal or any crap in it.
thanx im guessing the senors is...... i dont know lol any ideas? And where can i get a new sensor pep boys or a dealer?
Old Feb 22, 2003 | 11:46 AM
RamAir95TA's Avatar
Your best bet is through a dealer.
Courtesy shoebox (Rob):
http://csce.uark.edu/~jgbertr/rb/low_coolant.jpg
Old Feb 23, 2003 | 06:38 AM
Mtrhds94Z's Avatar
Stock stat is 180..
Old Feb 23, 2003 | 08:50 AM
Originally posted by Mtrhds94Z
Stock stat is 180..
...and stock fans come on at 226º.
You can try to clean the low coolant sensor, replace it or you can unplug it with no other ill effects. You just won't be able to monitor the level any more with the light.
Old Feb 23, 2003 | 09:52 AM
thank you guys very much
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
