Air/Fuel ratio monitor
Old Feb 20, 2003 | 11:15 PM
amjadZ28's Avatar
Arrow Air/Fuel ratio monitor
guys with air/fuel ratio gauge how do you wire that on your cars.
I have true dual so should I just buy another Oxygen sensor and but it in the X pipe? or it dose not matter if I connect to just right or left sensor.
Old Feb 26, 2003 | 03:59 PM
amjadZ28's Avatar
any one please
Old Feb 26, 2003 | 04:15 PM
You connect the A/F gauge to the existing O2 sensor signal wire. You can tap into the harness wire (not the sensor wire) or the PCM terminal. One side is a purple wire, the other is a purple wire with a white strip. As I recall, they are PCM pins C8 and C20. You can actually wire both sensors to a single-pole, double-throw switch, that allows you to select either sensor. You don't want to put another sensor far away from the engine, like in the X-pipe, since it will typically not get hot enough to work reliably.
As I am sure you have heard, the A/F gauge will do little more than provide you with a psychedelic light show, and the stock O2 sensors are only accurate at 14.7:1 (idle and low/part loads), not at WOT.
FastGuyJR's Avatar
Right or left. Doesn't matter. I have mine hooked into my driver's side O2. If you want to look at both, you can install a switch to alternate which O2 wire signal is sent to the gauge.
JR
Old Feb 26, 2003 | 04:24 PM
FastGuyJR's Avatar
Yes as Injuneer said, it's more like just a psychadelic light show, not too helpful at all. The only real thing you can read with it is if you're misfiring, in which case it will read very lean for about a second or less.
JR
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
RUENUF
Mar 13, 2016 03:37 PM
Z Power
Sep 19, 2015 11:19 PM
Aug 7, 2015 01:26 PM
