SLP STB Install problem
Old Feb 20, 2003 | 08:20 PM
Corp's Avatar
Well after wrestling the STB around the brake lines I move to the passenger side and see that theres some type of A/C sensor in the way. SO I unclick the connector, remove the sensor, and install the STB over the mounting bolts.
The problem lies in the fact that I cannot re-thread the sensor back on. There is no room for it as the STB is in the way. Not to mention that the STB rubs on the thicker A/C metal line when its torqued down. I can't beleive an SLP part has such bad fit.
This didnt appear in the instructions and I couldnt find reference to it in any posts I searched. AM I missing something here?
Help is appreciated
Old Feb 20, 2003 | 09:23 PM
Buttercup's Avatar
All STB's have this problem. I simply unplug the A/C pressure sensor, loosen up the bracket on the A/C evaporator canister, and gently push on the A/C lines until you have the clearance. I've always installed mine on the passenger side first which might help you out.
Old Feb 20, 2003 | 09:31 PM
94ltwonz28's Avatar
that line with the sensor bends very very easy, dont worry you wont break anything
Old Feb 21, 2003 | 10:29 AM
Corp's Avatar
Where exactly is this brakcet? Is it the black one that encircles the canister? Its only got one bolt? Is that it?
Old Feb 21, 2003 | 05:21 PM
94ltwonz28's Avatar
on mine I just grabbed the sensor and bent it towards the sky, turning it clockwise and it clears nicely
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Richardan15
May 30, 2015 08:36 AM
Don 97 SS
Jul 11, 2005 08:50 AM
Z28STYLE23
Aug 17, 2002 07:40 PM
