HP and Rocker arms
Old Feb 20, 2003 | 07:12 PM
nB5sP's Avatar
HP and Rocker arms
is it possible to get good gains from getting new rockers?
i saw some crane rocker arms in summit and they said it can add up to 25 HP. is this true? i'm also running a stock cam.
also what size would be best? thank you!
Old Feb 20, 2003 | 07:19 PM
blownbird01's Avatar
Going to a 1.6 full rollerwill be worth about 20-25hp. Buddy of mine installed a set and picked up 2mph and 2 tenths at the race track. They reduce friction and give more lift when you go with a 1.6 ratio.
Old Feb 20, 2003 | 07:25 PM
craigffb's Avatar
I got 0 gain with gain at the track with mine. It did get rid of a valve foalt problem when I put on the new springs.
Old Feb 20, 2003 | 07:27 PM
nB5sP's Avatar
do you mean when you installed new rockers or valve springs?
Old Feb 20, 2003 | 07:32 PM
ba96ta's Avatar
That is the next mod on my list I have heard nothing but good things adout them
Old Feb 20, 2003 | 07:53 PM
robob's Avatar
I had my '96 WS6 dynoed before and after 1.6 Crane installation. Net gain in SAE torque = 12 lb. ft., SAE H.P. = 20 H.P.
The engine is stock except for the usual K&N, underdrive pulleys, MSD 6, MSD coil, throttle body bypass, Borla exhaust. Last dyno was 286 H.P. and 308 lb. ft. at the wheels with the 6 speed.
New valve springs will help also if you have some mileage on the engine. The Cranes will fit under stock valve covers.
Old Feb 20, 2003 | 09:14 PM
craigffb's Avatar
I did them at the same time. I run my car about once a month and I had no gain (ET or MPH) from 1.6 rockers.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
