Do 93's have a knock module??
Old Feb 20, 2003 | 04:53 PM
pearlpurple's Avatar
If they do could you use the LT4 knock module on a 93 and would it be of any benefit even with a stock motor??
Old Feb 20, 2003 | 05:36 PM
93Z4ME's Avatar
No knock modules until 94. Main benifit of a LT4 KM on a 94+ is to prevent ignition retard from occuring if you upgrade to self aligning roller rockers (like on an LT4) which create alot of noise which gets interpreted as knocking, The LT4 KM is less sensitive.
So on 93 cars you can make them as noisy as you want and only iritate yourself.
Old Feb 20, 2003 | 06:13 PM
DjArcadian's Avatar
They have a KM but you can not use an LT4 KM. There are instructions somewhere on the web showing you how to desensitive the stock KM.
Old Feb 20, 2003 | 06:18 PM
93Z4ME's Avatar
thanks pearlpurlple,
I didn't know I had anything to worry about, I was planning on installing non-SA rockers just cause I don't like needless noise but this gives me yet another reason.
Old Feb 20, 2003 | 09:45 PM
neversummer's Avatar
Is this the link?
http://www.geocities.com/MotorCity/6647/ta93/knock.htm
Anyone had experience? Or a better question, is there a way to compare LT1 to LT4 KM, and then "apply" that change to the 93 module?
Old Feb 20, 2003 | 10:09 PM
JJJ93z's Avatar
Our 93's have a knock sensor not a knock module the knock module is the chip in the pcm and theres not one there . just my $0.2!
Old Feb 20, 2003 | 10:10 PM
Shayne's Avatar
Does anyone know where to get a lt4 km?
Old Feb 20, 2003 | 10:30 PM
93 owners, I'm reading different things here. All I care about is this: Can I be a noisy Fothermucker and not worry about knock retard? (READ - straight pipe, valvetrain, all future plans.)
If not, what do 93 owners do? Thanks.
Nate.
Old Feb 20, 2003 | 10:55 PM
JJJ93z's Avatar
Part No. 16214681 carried at any gm dealer for about $27
Old Feb 20, 2003 | 11:19 PM
KCFormula's Avatar
Nate.
I wouldnt worry about it. I hear they are not nearly as sensitive as a reg LT1 KM. If you worry about it just run a scan tool and look for it, and if you find some you can always desensitize it.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
