what do u think the gains will be???
Old Feb 19, 2003 | 11:55 PM
hitman8728's Avatar
Exclamation what do u think the gains will be???
hey guys i knowno on ewill be right on but im wonderign what around my 1/4 going to be with a 75 shot of nx im running a 14.00@99.98mph and what to u htink i would be with the 100shot also? thank you to every one who puts out there guess
Old Feb 20, 2003 | 08:19 AM
mtxpert's Avatar
You'll pick up about .75 to 1.0 with a 75 shot and 1.0 to 1.5 with 100 shot. The variance is traction related and how well you can handle the extra torque off the line.
Also the faster you are baseline the less you gain..
I had a 17.2 second 305 Caprice back in 95 that would run 15.0's with a 150 shot.
Mike
Old Feb 20, 2003 | 09:04 AM
dabear95's Avatar
Mike
So, lets take this car. Install all forged bottom end. Run it to 8,000 RPM and hit it with a 1000 shot and see what happens...
17.2 NA
9.7 N2O
lMAO
Old Feb 20, 2003 | 09:49 AM
COMNBYU's Avatar
it is true that closer-to-stock cars WILL gain more from a particular shot of n2o than a modded car.
for EX- my 96 Z, when it was bone stock, ran a best of 13.6 and normally ran .7s/.8s. i put about a 50-60 shot on with NO modds and on radial tires ran a 12.7 spinning.
now, a good friend of mine has a built mustang that runs high 10s NA. hes going to be running a 200shot in hopes of getting into the 9s.
hope that helps some. as for your car, i would say (assuming adequate traction) you could run low 13s/high 12s on a 75 and solid 12s on a 100.
good luck and be safe!!!!
jon
Nutty's96
Dec 21, 2015 06:25 AM
colts0455
Sep 22, 2015 02:03 PM
colts0455
Sep 2, 2015 12:41 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Beave2780
Jun 11, 2015 07:57 PM
