OBDII Idle Timing
Old Feb 19, 2003 | 07:04 PM
TimChiaretto's Avatar
Question OBDII Idle Timing
Here's what I have - 97 with OBDII and an A4 trans. When I set the "Closed Throttle Spark Adv." to 24 degrees for the idle rpm range that is the amount of advance I see with Autotap WHEN THE A4 IS IN PARK, but whe I put it in gear I see from 28 to 32 degrees (usually 29 to 30). It doesn't seem to matter at all what I set in the "Load vs Adv." area. I have changed it in the idle range from 4 degrees retarded to 4 degrees advanced in the in gear idle values and everything close to them. Upload the program, run the car, there it is 28 to 32 degrees of advance at idle. I don't know what I'm doing wrong, please help. Thanks in advance.
Fatdog2
Feb 13, 2015 08:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
