gasket part #s?
Old Feb 19, 2003 | 06:12 PM
95BLKTA's Avatar
gasket part #s?
what kinda gaskets am i going to need to do the hot cam install?
im thinkin just the timing chain cover?
anybody got part #s??
Chris
PS Jason Cromer is backordered on the Hot Cam kit
Old Feb 19, 2003 | 08:11 PM
95BLKTA's Avatar
TTT
Old Feb 19, 2003 | 08:19 PM
96cam4ro's Avatar
Valve cover gasket, timing cover gasket and water pump gasket..you can get all of them from Autozone. Sorry to hear about Jason - he's the cheapest around.
Old Feb 19, 2003 | 08:36 PM
95BLKTA's Avatar
thanks,
i ended up getting it from GMPartsdirect.com, i prob should have done it that way anyway since i would have had to pay the tax, cause i live in FL
wasnt sure about the valve cover gaskets, either, for some reason i thought they were self sealing(for some reason??)
i see you have about the same mods im going to have soon.
have you been to the track, what are your times
my mods:
ram air
MSD
TB Bypass
the new Jet Hot long tubes
no cats
LT4 Hotcam
with 1.6 RRs and LT4 Springs
LT4 Knock module
LCAs +PHR
Aluminum Drive Shaft 1LE
Flowmaster Cat Back
i also have the C% rims with Nitto 555s
but mines an M6
thanks
Chris
Old Feb 19, 2003 | 08:44 PM
nateh's Avatar
Timing cover gasket GM 10128293. $2.19 from Jason, probably about $3.50-$4.00 from your local gouging dealer.
Water pump gaskets: GM 10128343
3 seals: Optispark seal - GM12552428, Crank seal - GM 10128316, Water pump drive seal - GM 10217886
Intake gaskets (don't have the PN)
You can use the valve cover gaskets again.
Old Feb 19, 2003 | 09:24 PM
96cam4ro's Avatar
Originally posted by 95BLKTA
thanks,
my mods:
ram air
MSD
TB Bypass
no cats
LT4 Hotcam
LT4 Knock module
LCAs +PHR
Flowmaster Cat Back
but mines an M6
thanks
Chris
Wow I forgot about the intake manifold gasket!! Be sure to get BLACK rtv silicone becuase you don't want to have the infamous 'intake manifold' leak.
Goin' to the dyno tommorrow if they can fit me in. Going to the track next week. Good luck on the install.
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
