Lobe Seperation ??
Old Feb 19, 2003 | 05:10 PM
UNV MI Z's Avatar
Lobe Seperation ??
383 is being built as we speak. Forged everything, ported heads, etc.. Question is - I bought a Comp Cams Xtreme Energy cam, it's a 236/242. I haven't looked for sure yet, but I think it's has a 110 lobe seperation. I am just wondering how this will effect me. Will this not work with my setup?? Camshaft details are the only thing about a motor that I really don't understand. So all your help is appreciated. Details are 383, forged parts, ported heads with dual valvesprings, 1.6 rockers, etc.., you get the picture. Just unsure about the cam. Also, are titanium retainers a must with this cam?? Thanks in advance for the help.
Seth
Old Feb 19, 2003 | 05:29 PM
shocktrp's Avatar
Stock LSA is 117
Hotcam LSA is 112
You should have a little more lope than the Hotcam, but it should be fine with PCM programming.
Old Feb 19, 2003 | 05:30 PM
RamAir95TA's Avatar
Your manifold vacuum may be uncomfortably low for power brakes. You might want to consider a seperate vacuum canister. You'd benefit alot, considering at stock idle rpms, you'll stall out. Have your idle raised to 1000rpm with that kind of bumpstick.
Old Feb 19, 2003 | 05:49 PM
UNV MI Z's Avatar
Thanks for the replies. So the only thing I might lose is some vacuum?? If I went with the same cam but with a 112 lobe seperation would I still have this problem. Just trying to figure out if I need to switch to the 112 or not. Also, do I need titanium retainers with this cam??
thanks
Old Feb 19, 2003 | 06:53 PM
shocktrp's Avatar
My brakes feel the same with the Hotcam as they did with the stocker.
Old Feb 19, 2003 | 07:56 PM
97Z-M6's Avatar
but the 236/242 makes the hotcam look very small. with the lsa of 110 and 236/242 duration the overlap is more than if it were on a 112. and overlap really affects the drivability. but the the added cubic inches will tame it out a little
95chwagon
Oct 16, 2015 12:24 PM
oil pan 4
V6 Tech
Nov 9, 2002 07:27 PM
qukz28
Oct 27, 2002 01:31 AM
Blown350Camaro
3rd Gen / L98 Engine Tech
Oct 24, 2002 10:59 PM
70 Cam Guy
Classic Engine Tech
Aug 26, 2002 08:43 PM
