roll cage, when it it time?
Old Feb 19, 2003 | 12:53 PM
camaroSSlover's Avatar
what's the rule book say if you go 10's you need a cage? would the extra lbs. hurt times on a 12.xx car but make it up in less chassie flex?
Old Feb 19, 2003 | 01:08 PM
LPEdave's Avatar
Unless you change the firewall, you need a cage at 9.99. At 12.x, you need no cage or bar, and I suspect the added weight of either will slow you down more than "less chassis flex" will speed you up.
Dave
Old Feb 19, 2003 | 03:13 PM
jonaddis84's Avatar
I thought it was 11.999 or better and you needed a rollbar, a cage for 9.999 or better.
If you plan on throwing a lot of power right to the ground, aka 300+ hooking with DRs or slicks, and you plan on keeping the car a while, Id get a cage, with all that power hooking right up the frame will bend slightly. Plus its kind of cool knowing theres like a 75% less chance of dieing in an accident.
Old Feb 19, 2003 | 04:12 PM
chesee48's Avatar
Yea i thought it was 11.99 around here too...
Whats the cost of a rollbar compared to a cage? i wont be running 9.999, but i better be in the 11's...
Old Feb 19, 2003 | 07:36 PM
jonaddis84's Avatar
I got a quote from a guy that builds race car chassis (tube chassis cars) like 6 and 7 second cars. He also does custom fab stuff for street cars. For a six point chromoly, bent how I want it, installed, not painted, he does all the stripping that he needs to. He quoted me $600. A wolfe cage is like $400 or $450 for a weld in chromoly, then you have to get it installed which around here is about $200, so either way around $600, Id rather have it my way instead of wolfes way.
Old Feb 19, 2003 | 08:48 PM
dnz28's Avatar
It is 11.99 and if your car is a convertable its 12.99 I think also goes for t-tops to
Old Feb 19, 2003 | 10:03 PM
sleeperZ96BT's Avatar
depends on the track and the car. i know a coupe tends to be 11.99 or 11.49 or faster, or close to it. just check your local tracks rules and they should say what you need, when, and where.
brian
Old Feb 20, 2003 | 08:18 AM
CANTONRACER's Avatar
I belive NHRA is 11.99 and IHRA is 11.49...not sure...but along with your cage you'll want a ds loop.
I have a local guy who said he will put in an 8 pt for me, legal and hidden as best possible for $700 cash. He understands I am really into the sleeper look so he said he would do a kick *** job.
Old Feb 20, 2003 | 08:22 AM
dabear95's Avatar
I think a DS loop is something anyone with an F-body that is drag racing should look into...
I installed one after I watched a fellow F-body member loose his driveshaft in a violent manor.
Jason
Old Feb 20, 2003 | 09:20 AM
RobK's Avatar
The good book says:
hardtops:
11.99 needs a rollbar
9.99 needs a rollcage
ragtops & the like:
13.99 needs a rollbar
-Rob
Old Feb 20, 2003 | 10:39 AM
chesee48's Avatar
How much is a typical Roll Bar Install??
Old Feb 21, 2003 | 04:09 PM
Toph's Avatar
The install is most likely going to be around $500 for quality work. The bar itself is the inexpensive part.
Old Feb 21, 2003 | 04:21 PM
TedH's Avatar
11.99 NHRA
11.49 IHRA
Get a good one. I have a six point wolfe bar, welded. It adds stiffness and looks good. It is your life you are playing with so do it right.
A driveshaft loop is also needed, and you may as well get a 5-point harness as long as you are doing a cage or a bar. 5-points expire every two years at both IHRA and NHRA so don't buy a used one. This is money well spend. A flat tire or a dragster coming up your butt can hurt at the top end.
Old Feb 21, 2003 | 05:22 PM
augi's Avatar
I have t-tops so when do I need a roll bar?
Old Feb 21, 2003 | 06:27 PM
sseeya's Avatar
11.99
