oil leak?
Old Feb 18, 2003 | 02:32 PM
Haskin Z28's Avatar
oil leak?
under the front of the car it looks like there may be some oil leaking, guy at midas said it was the front seal, are these expensive? also my air filter when it was last cleaned was cleaned and dried (he used high pressure air ) and then it wasnt re-oiled, also my alternator is busted, what am i looking at total in repairs?
Old Feb 18, 2003 | 02:40 PM
EviLBoX's Avatar
I noticed the same oil leak under the front of my car. Is it right under the optispark behind the large pulley wheel? From reading on this message board I think it may be the timing chain cover, but I'm not sure.
I'm not sure how much an alternator costs, but I'd guess anywhere from $80-$150. I wouldn't pay someone to replace that, it's very easy to replace on our cars, just a few bolts.
Old Feb 18, 2003 | 02:41 PM
z28Power's Avatar
Well, I'm not sure how much the front seal actually costs in terms of the part itself.
You didn't list any modifications to your car, so assuming that you have a stock air filter in the stock box, you should be OK on the air filter itself, if it does need to be replaced, a new paper filter is fairly cheap. Might as well use this opportunity to put a CAI on there though. (If it's broke, upgrade it!) The alternator shouldn't be too bad of an install, both of these two repairs you could do yourself to save the repair costs. You can pick up an alternator at AutoZone or PepBoys for $150-200.
Old Feb 18, 2003 | 02:57 PM
Haskin Z28's Avatar
i didnt mention them because they're in the sig
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
