Most powerful engine in a production GM car?
Old Feb 18, 2003 | 01:02 PM
newby's Avatar
With all the talk of the new engines/models/etc coming from GM, I got to wondering what the most powerful engine GM every offered in a production car was.
To my knowledge it was the L88 Corvette engine, which although rated at 405ish by GM, was dynoing at closer to 550-560hp. I know that was a production car, but you couldn't get it with a heater or radio.
Has there been something more powerful than that ever offered to the public? The talk of the new C6's possible power numbers is what got me thinking the most.
Old Feb 18, 2003 | 01:04 PM
Meccadeth's Avatar
Didn't Pontiac offer a big block in the Trans Am like 30 years ago? I know it was no where near 560 HP though...
Old Feb 18, 2003 | 02:49 PM
91_z28_4me's Avatar
I would think that the L88 would be outdone by its aluminum brother the ZL1 I mean that was a race engine, but only 69 total were made. If not that then how about the 455 SD trans am motors I don't know personally but I have heard that the pontiac motors made HUGE torque numbers.
Old Feb 18, 2003 | 02:51 PM
Meccadeth's Avatar
Yea, thats the one I was talking about...the 455
Old Feb 18, 2003 | 02:52 PM
Z28x's Avatar
future engines:
7.5L V12 500HP+ rumored to go into an Escalade V-series
twin turbo Northstar 450HP+ rumored for XLRv and STSv
C6 6.0L V8 400HP+
and then there is the HP3 8100 engine, 525 horsepower and more than 560 lb-ft of torque, but you can only get it in create form
http://www.gm.com/automotive/gmpower...ws/press16.htm
Old Feb 18, 2003 | 03:08 PM
jg95z28's Avatar
From an F-body perspective....
The 455-SD was rated at 290hp/395 ft-lbs, whereas the L-78 Camaros (396 ci in 1969, 402 ci in 1970) were rated at 375hp/415 ft-lbs. But I don't think you can actually compare the the two.
Old Feb 18, 2003 | 03:41 PM
Decromin's Avatar
The HRT427 has been officially announced for production later this year - it's not been made public, but the power is expected to be around 530-550hp
Old Feb 18, 2003 | 04:16 PM
guionM's Avatar
First, remember that cars before 1972 and cars 1972 onward are rated by 2 entirely different standards.
Prior to 1972, all cars were rated by gross horsepower, pretty much measured by the engine sitting by itself on a dyno without even the alternator or anything else attached to it, at what ever conditions made the most power.
From 1972 onward, engines were rated by SAE net horsepower, which is pretty much as installed, at the flywheel, with production exhaust, production accessories, pollution equptment, and production intake system installed at a set temperture, humidity, and atmospheric pressure.
What this means is that a 500hp pre 1972 engine actually makes less horsepower than a post 1972 engine making, say, 400hp.
In 1971 under the old standard, the LS5 made 365hp and the LT1 made 330. Under the new standard the following year, the LS5 and LT1 made 270hp and 255hp respectively, despite having the same pollution equptment as they did in 1971.
So it can argubly be said the current 500hp Viper engine is the most powerful production engine ever offered to the general public in a regular production car, since it would have in excess of 600hp by the old Gross Horsepower standard.
That would also make that 427 Holden small block very very impressive in 1971!
Old Feb 18, 2003 | 04:19 PM
Ed 2001 SS's Avatar
.....unless I missed something, Vipers aren't GM cars
Old Feb 18, 2003 | 04:24 PM
Meccadeth's Avatar
Wow...is there a webpage citing all of this? Or is this your existing knowledge?
Old Feb 18, 2003 | 04:35 PM
newby's Avatar
Wow! You learn something new every day! Thanks for the info guionM.
guionM's Avatar
Didn't miss anything, my bad.
Well, in that case, perhaps a tie between the Z06 & ZR1 Corvettes? Both put out a maximum of 405hp, which would put it over 500 by the old standard, as much as (if not more than) the L88 Corvette.
I wouldn't exactly call the ZL1 a regular production engine since less than 6 dozen were made. There's back yard operations that make more engines than that.
Now, if you mean TORQUE then we may have a different story. Someone can look it up, but the old Cadillac 500cids V8s were toting 500 ft/lbs of torque under the newer lower standards.
Buick GNX of '71 had the same, but it was under the more generous rating.
Old Feb 18, 2003 | 04:46 PM
guionM's Avatar
It's pretty much in every manual that deals with engines. If it has both pre & post '72 ratings, everything after 1972 will be called "net horsepower" and everything before will be called "gross horsepower" and you'll notice a very very serious drop in power ratings that same year (it's not from new pollution equptment, which didn't really start sapping major power from engines till 1973-1976. 1971 & 1972's pollution equptment was pretty much identical) .
If you want to dig out more info, it's called SAE Standard J1349, and it became the industry standard in April 1972, I think.
Old Feb 18, 2003 | 11:53 PM
Chuck!'s Avatar
Those old caddy 500s could pull all of hell onto the surface of earth will their torque.
Old Feb 20, 2003 | 10:49 AM
detltu's Avatar
Actually 71 ZL1 s were made 69 in Camaros and 2 in corvettes, its probably the most powerful engine put in a Chevrolet car, but i dont know about pontiac.
