adding an amp
Old Feb 18, 2003 | 10:42 AM
kahouna23's Avatar
Question adding an amp
I feel extremely stupid on this on because I should know. BUT.......for those of you who've added an amp to the Monsoon system, maybe you can helpl me. My stereo is all stock, and I've added an amp, x-over, and line converter to my system. My question is, with everything wired up I'm not getting much power to the sub. It seems as though I might have wired into something that's drawing power from my amp. I spliced into the right rear speaker and that goes to the line converter, then to the x-over, then to the amp. I've gone over the wires over and over again, but I just can't figure it out. I really wish the stock head unit had RCA outputs so I could eliminate the line converter, but I don't want to change out the head unit since it's a double din. I dunno, maybe someone can come up with something I'm overlooking. I feel like a complete retard, so someone please help me out if you can......
Old Feb 18, 2003 | 05:12 PM
x7x7's Avatar
Two things I can think of to consider:
1. Have you tried turning up the gain on your LOC if it has one (it should).
2. The outputs you're trying to use may have a crossover upstream so you're not sending I full range signal to your amp/x-over.
Old Feb 18, 2003 | 09:22 PM
kahouna23's Avatar
In terms of an "upstream" crossover, is that something that's installed on the speaker itself? I noticed that there are 4 wires going to the speaker. I'm guessing it's the high and midrange, seeing as how it's a 2-way speaker. Any idea which ones are for the midrange and which ones are for the high. I might have spliced into either the high or one of each. That would suck if that's the case. Is there a wiring schematic online somewhere that I can reference to? Of course the wiring for the Monsoon isn't in my service manual so I'm kinda at a loss here.
Old Feb 18, 2003 | 10:18 PM
BandDirector Blk98ZM6's Avatar
The BEST place to tap a signal from the Monsoon system is behind the head unit. All speakers in the Monsoon are x-over by the Monsoon amp (except the front tweetes, they're run off the HU), so that's why you're not getting enough bass.
Check out the FAQ's at the top of the Electronics Forum over at www.ls1.com for all the information you could possibly want to know on adding on to the Monsoon system. It's a long thread, but worth the read. It has the diagrams you're looking for as well.
Old Feb 18, 2003 | 10:19 PM
kahouna23's Avatar
Thanks for the reference......much appreciated!
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
marlar98
Sep 19, 2015 07:53 AM
RX Speed Works
Sep 11, 2015 03:31 PM
cmsmith
Aug 27, 2015 06:37 PM
